SuiteSuccess Posted September 24, 2015 Report Share Posted September 24, 2015 I know this has been discussed in the past but searched and couldn't find thread. I have the Xantrex 1800HF Inverter/Charger installed. I recently moved to a covered storage facility that has 110 plugs so I can stay connected to 20 amp shore power. The charger is 3 stage with bulk/absorption/float. My batteries are sealed with no caps. My question: will I harm anything by leaving my inverter/charger plugged in continuously? I can't add water to my batteries but don't think they could also boil off. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 24, 2015 Report Share Posted September 24, 2015 The default float for that charger is 13.5 volts, which should be OK. That is set for Flooded cells. If you want to drop it one/tenth more volt to 13.4 volts you can set it for AGM. But then you will not get as good a bulk charge. It should be OK as is. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted September 24, 2015 Report Share Posted September 24, 2015 The default float for that charger is 13.5 volts, which should be OK. That is set for Flooded cells. If you want to drop it one more volt to 13.4 volts you can set it for AGM. But then you will not get as good a bulk charge. It should be OK as is. One volt or 1/10 of a volt?? Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 24, 2015 Report Share Posted September 24, 2015 One volt or 1/10 of a volt?? Sorry - on tenth.... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 24, 2015 Author Report Share Posted September 24, 2015 Thanks Jack and TK. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Yarome Posted September 24, 2015 Report Share Posted September 24, 2015 If you have any qualms, you could always just keep it on charge every couple to three months while in storage and let it self discharge in the interim if you're at all concerned about water levels. I don't know of a battery out there that doesn't like to 'stretch it's legs' at least a little to stay healthy. Link to comment Share on other sites More sharing options...
