flightdoc1 Posted December 1, 2015 Report Share Posted December 1, 2015 Hoping someone can help. I'm not very savy when it comes to mechanics. I purchased a Cobra CB radio and not sure how it needs to be installed. I own a 2009 Monaco Monarch Thanks Vin Link to comment Share on other sites More sharing options...
flightdoc1 Posted December 1, 2015 Author Report Share Posted December 1, 2015 Thanks for the help. Vin Link to comment Share on other sites More sharing options...
Kirk W Posted December 2, 2015 Report Share Posted December 2, 2015 This article gives you a good idea of how and why: http://www.wearecb.com/how-to-tune-cb-antenna.html Excellent article! Thanks for posting the link. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
scouserl41 Posted December 2, 2015 Report Share Posted December 2, 2015 If you don't already have an antenna then you will need one suitable for a glass fiber body. The antenna needs a ground plane and fiber glass won't do it. Try a marine/boat store, they'll know what you need. Get one with a spring at the bottom so if you brush a tree branch it wont snap off the antenna or tear a hole in your roof. 2009 Monaco Cayman DP 38' bnbrv.blogspot.com/ Link to comment Share on other sites More sharing options...
chuckbear Posted December 3, 2015 Report Share Posted December 3, 2015 We used the Firestick antenna specifically designed for fiberglass bodies. That is what you will need if you are mounting to a typical RV, a no ground plane antenna. It does not have to be a marine antenna, they will cost you more and usually have a totally different mounting configuration. You will also need an SWR meter to tune the antenna after you have done the install. Many CB's have a built in SWR meter, but they are not adequate for tuning. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
