dreamscape Posted December 5, 2015 Report Share Posted December 5, 2015 We have the WiFi Go Ranger, with the Phantom 7.0.2 Firmware. We've had this installed with the WFRBoost and a smaller antenna. They say that the Boost is outdated and is not supported well by the Go. How can I get rid of it in the Control Panel? It seems to conflict with it and it and our signal keeps dropping out. I've sent them screenshots of how we have it setup and everything is fine. "It sounds like the issue may be that the WFRBoost has an IP address conflict with the NETGEAR. Change the IP address of your WFRBoost to avoid future IP conflicts:1) Go to the WiFiRanger Control Panel2) Select Setup tab3) Click WFRBoost hyperlink (takes you to AirOS control panel for WFRBoost)4) Enter ubnt / ubnt for the username / password5) Select Network tab6) Change IP Address from 192.168.1.20 to 192.168.250.207) Save changes8) Go back to the WiFiRanger Control Panel9) Expand the WFRBoost settings on the Setup tab10) Enter 192.168.250.20 to replace 192.168.1.2011) Click Save12) Reboot both WiFiRanger and WFRBoost13) Ensure WFRBoost is still configured and then try connecting to the WiFi networkThis should avoid the IP Conflict at this location, and many others as the 192.168.1.x IP scheme is very common." "Perhaps the WFRBoost is simply not compatible with that network. Since the WFRBoost is a very old technology, some networks don't work with it" I also would like to install a TL-ANT2412D antenna for better reception. Can I just remove the Boost and hook up the antenna? Are there any configurations that need to be changed? Becky and Paul Lawry 1968 Silver Eagle Model 01 VIN # 7443 8v71 Allison HT 740 2011 Buick Enclave Full Timing Our Travel Blog Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 5, 2015 Report Share Posted December 5, 2015 It IS a good idea to change the default IP addresses as indicated. I would do that. As to the antenna, you can replace the Laird (stubby antenna) with any antenna with the right connections. The issue is going to be haw will you physically support it. That 12 dbi antenna is very large and will put a lot of strain on the connector. There are ways around this, but none of them are a total solution in an RV environment - at least for a permanent mounted system. Using that setup I'd use a pole mount and mount it as needed. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
dreamscape Posted December 5, 2015 Author Report Share Posted December 5, 2015 I have changed the default IP address already. I'm thinking of mounting it to our Sensar antenna just like the short one. I think I can work around the strain on the connection. If there is nothing else I need to do, I'm going to give it a whirl. Thanks for your comment Jack! Becky and Paul Lawry 1968 Silver Eagle Model 01 VIN # 7443 8v71 Allison HT 740 2011 Buick Enclave Full Timing Our Travel Blog Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 5, 2015 Report Share Posted December 5, 2015 You just need to seal it up good, or you WILL have issues. Use Coax Seal over GOOD quality tape. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
dreamscape Posted December 6, 2015 Author Report Share Posted December 6, 2015 Will do, Thanks! Becky and Paul Lawry 1968 Silver Eagle Model 01 VIN # 7443 8v71 Allison HT 740 2011 Buick Enclave Full Timing Our Travel Blog Link to comment Share on other sites More sharing options...
