runaway parents Posted August 5, 2016 Report Share Posted August 5, 2016 So I understand the hole regen process on my 08 volvo780. I know it creates a lot of heat under the floor board on the passenger side of the truck.it burns the diesel particulates in the dpf filter. Turns it into ash and sends it out the tail pipe. Now the question I have is, When this ash leaves the tail pipe is it hot enough to start a brush fire or a forest fire for that mater. if the exhaust pipe is configured in the "weed burner" position.Currently my stack is still over the cab. Sometimes I take rig on logging roads. Are logging trucks required to have some sort of spark arrester equipment on there truck to run on forest service roads. Don't want to be presented with a bill to put out a fire. Any advice would be highly appreciated. Link to comment Share on other sites More sharing options...
atv_idiot Posted August 5, 2016 Report Share Posted August 5, 2016 We go offroad a lot too., I just make sure to cancel a regen prior to leaving pavement. Link to comment Share on other sites More sharing options...
runaway parents Posted August 5, 2016 Author Report Share Posted August 5, 2016 sounds like good advice thanks Link to comment Share on other sites More sharing options...
runaway parents Posted August 5, 2016 Author Report Share Posted August 5, 2016 But still interested if this could be a potential problem. Link to comment Share on other sites More sharing options...
runaway parents Posted August 6, 2016 Author Report Share Posted August 6, 2016 any body got any ideas Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 6, 2016 Report Share Posted August 6, 2016 I'd be talking to Volvo engineering to see if they offer an under-body exhaust for box trucks. There's a lot of slide rule time involved in modern exhaust, not just fitting all the parts in place, but ensuring temps are maintained in the crucial range. Any emissions inspection requirements need to be kept in mind, too. As far as will the ash catch the road-side on fire? Too many variables to answer. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
runaway parents Posted August 7, 2016 Author Report Share Posted August 7, 2016 Thank you for your response I live in Wenatchee wash. Over the last few years we have had some extreme wild fires. Just concerned. Guess a little jumpy. Thanks. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 7, 2016 Report Share Posted August 7, 2016 Apples to oranges, I know but the LDT trucks run re-gens as the system tells them to, off-road or on, freeway or suburban streets. I have honestly never noticed any modern diesel during a re-gen. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
noteven Posted August 7, 2016 Report Share Posted August 7, 2016 The soot is reduced to ash. The ash an particulates remain in the filter. It needs periodic cleaning. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Scrap Posted August 7, 2016 Report Share Posted August 7, 2016 The truck that shot sparks and burned down half of the Yakima area a few years ago was a CARB retrofit DPF and not OEM. They have since been recalled/sued/put out of existence. But still it is 1000 some degrees coming out of the DPF so a diffuser tailpipe is needed if changed to a horizontal exhaust. Especially on a 08-10 without an SCR can to absorb some heat. Also as said above know your truck, know it's cycle, and cancel a regen way before pulling off the pavement. Then get back out of there before it needs another. I don't know volvos but do their vocational and on highway sleeper trucks share the same DPF setup and just change location/tailpipes? If converting exhaust it would probably be prudent to change to whatever their vocational trucks use if it is going to be put in a vocational situation. Link to comment Share on other sites More sharing options...
runaway parents Posted August 7, 2016 Author Report Share Posted August 7, 2016 Sounds like good advice. My exhaust will remain stock over head and will make sure I cancel regen when going off road. Better safe than having a big bill to pay for. Link to comment Share on other sites More sharing options...
Larry&Donna-AK Posted August 8, 2016 Report Share Posted August 8, 2016 This is Volvo's recommendation "During active regeneration, the exhaust outlet temperature is extremely high. So watch your location if regeneration is about to begin. If you are entering a location where high exhaust temperatures might be unsafe - a crowded work site, a fueling station or a tunnel, etc. - you should cancel the regen." I would say, if your traveling logging roads qualifies "unsafe". Planning Nanook version 2.0 Nanook "When we made ready to depart, after a few days, Nanook was beside himself with joy. Hudson Stuck Link to comment Share on other sites More sharing options...
runaway parents Posted August 8, 2016 Author Report Share Posted August 8, 2016 Hey Larry and Donna thank you so much for the great advice. I know what needs to be done now .to keep things safe. Link to comment Share on other sites More sharing options...
