Doug&Linda Posted May 30, 2018 Report Share Posted May 30, 2018 Can anyone explain why my water pump, every few minutes, makes a vibrating sound for a couple of seconds? Is this normal? Link to comment Share on other sites More sharing options...
chirakawa Posted May 30, 2018 Report Share Posted May 30, 2018 Most likely because you are losing pressure somewhere. Do you have a drip? Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 31, 2018 Report Share Posted May 31, 2018 Do you have your directional valve in the correct position ? Goes around , comes around . Link to comment Share on other sites More sharing options...
Doug&Linda Posted May 31, 2018 Author Report Share Posted May 31, 2018 I’m not sure what you mean by directional valve? Link to comment Share on other sites More sharing options...
HERO Maker Posted May 31, 2018 Report Share Posted May 31, 2018 What rig do you have? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Doug&Linda Posted May 31, 2018 Author Report Share Posted May 31, 2018 2003 Sunnybrook 5th Wheel Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 31, 2018 Report Share Posted May 31, 2018 2 hours ago, Doug&Linda said: I’m not sure what you mean by directional valve? The valve that selects City water or Local ( your on board tank ) water . Goes around , comes around . Link to comment Share on other sites More sharing options...
HERO Maker Posted May 31, 2018 Report Share Posted May 31, 2018 LIke Pat and Pete said. If it is not all the way turned correctly, you could have a problem pressurizing the system. You also could have a real small leak (drip, as was mentioned) somewhere in the system. Could be as small as a simple spray thru a crack in the line. If you get a chance to crawl under your rig, look for any wet spots in your belly. Do check each of your sink and shower shutoffs to make sure they are not leaking. I imagine that this only happens when you are on your water pump and not on city water? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
