hemsteadc Posted June 2, 2018 Report Share Posted June 2, 2018 delete Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted June 2, 2018 Report Share Posted June 2, 2018 Sounds like you either have a short between 12v and the backup light or the mechanism the turns the back up light on when you shift into reverse is stuck. I would start at the socket you were working on and assure all the wires are in the correct socket. Link to comment Share on other sites More sharing options...
hemsteadc Posted June 2, 2018 Author Report Share Posted June 2, 2018 No. it's much simpler than that. I inadvertently flipped on the backup lights switch on the dash. I rarely if ever use them, so I forget I even have them. Link to comment Share on other sites More sharing options...
Pat & Pete Posted June 2, 2018 Report Share Posted June 2, 2018 1 hour ago, hemsteadc said: No. it's much simpler than that. I inadvertently flipped on the backup lights switch on the dash. I rarely if ever use them, so I forget I even have them. Your simple mistake could help others to do the very same thing . LOL Why delete ? I think you should own up and re-title and re- post your OP . Goes around , comes around . Link to comment Share on other sites More sharing options...
Sehc Posted June 3, 2018 Report Share Posted June 3, 2018 Your a Senior Member. We understand. Link to comment Share on other sites More sharing options...
