SuiteSuccess Posted June 6, 2018 Report Share Posted June 6, 2018 Always nice to learn that you don’t know some things and need to leave it to the pros. Took my truck in to J&K Trucking in Crossville while camping at Deer Run for oil change and DOT inspection. I had checked truck over and under back in late March. Long story short, brakes were shot even though appeared good to me. Also found leaking seal. When mechanic showed me the pads there were hairline cracks on the outside but the inner part of the pad was cracked and crumbling. Hubs were scored. Replaced all four drive hubs and shoes. Thank heavens steers were ok. Mechanic mentioned that under heavy use those pads would eventually have come apart. WOW. Glad I found and corrected prior to our upcoming trips out west. Moral: I get yearly PM (oil, lube) but not DOT inspections but every 2-3 years. Think I’ll go to yearly like annual on an airplane. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
lockmup68 Posted June 6, 2018 Report Share Posted June 6, 2018 J&K hooked me up as well with the trans voltage doubler install and oil change. We headed out west as well. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
