bigredhdt Posted June 6, 2018 Report Share Posted June 6, 2018 Seems that more often the lower bots fuze to the shock. I used a cutoff wheel on the first one which took a while as i had to get the dual wheels off that were frozen to the hub. This turned into an 8 hour job after all was done. I had to put a jack between the opposite wheels to get them apart. I heard that people have had issues getting through the hardened bolts with a bimetal sawzall blade. In trying to find a faster way, I came upon a video of someone cutting a hitch ball with a sawzall. You need to use a carbide blade to get through the bolt. Both Lennox and Diablo make carbide sawzall blades. Get the "thick metal" blade. Took about 5 minutes for each cut and was able to do it without removing tires or airbags, and very little noxious smoke when getting through rubber. Link to comment Share on other sites More sharing options...
Parrformance Posted June 6, 2018 Report Share Posted June 6, 2018 Do the other airbags still stand behind you and tell you "your doing it wrong"? 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
bigredhdt Posted June 6, 2018 Author Report Share Posted June 6, 2018 Fortunately or unfortunately, I'm on my own when it comes to working on the truck. But the other airbags suggest I should pay for someone to work on the truck. Link to comment Share on other sites More sharing options...
Parrformance Posted June 6, 2018 Report Share Posted June 6, 2018 LOL 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Lance A Lott Posted June 6, 2018 Report Share Posted June 6, 2018 I had to cut mine with the cut off wheel also. I use it a lot so am very comfortable with it. You will be glad you pulled the wheels your self one day I bet. I put antizees on the bolts even though They will probably last me forever. I use the cut off wheel on Huck Bolts as well, cut 1/3 through and then a few whacks with a hammer and off they come, about 30 seconds each. Link to comment Share on other sites More sharing options...
GlennWest Posted June 6, 2018 Report Share Posted June 6, 2018 I use my 4" grinder with a 1/16" blade. That will cut anything fast. Even fingers if not careful. I use it for all my cutting, on a off the job. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Mastercraft Posted June 6, 2018 Report Share Posted June 6, 2018 My issue was the shock bushing had "Michigan Loctited" itself to the bolt on all 4 lower mounts. I put an air chisel on the bushing next to the rubber part for a minute or two, the Loctite turned to powder and I was able to get the bolts out. New shocks made a big difference, not in the ride but in the side to side sway, especially in corners. Doesn't feel like it needs a rear sway bar any more. 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
runaway parents Posted June 6, 2018 Report Share Posted June 6, 2018 I wonder can a person weld a piece of half inch all thread onto the head of the bolt going threw the shock, make it about 6 inches long slide a piece of pipe just big enough so head of bolt will go inside it . make pipe about 5 inches long throw a 1/2 flat washer of on top of pipe with all thread going threw it install 1/2 inch nut to all thread. Voila home made bolt puller. Don't know may have already been done. might be worth trying. Link to comment Share on other sites More sharing options...
rickeieio Posted June 7, 2018 Report Share Posted June 7, 2018 1 hour ago, runaway parents said: I wonder can a person weld a piece of half inch all thread onto the head of the bolt going threw the shock, make it about 6 inches long slide a piece of pipe just big enough so head of bolt will go inside it . make pipe about 5 inches long throw a 1/2 flat washer of on top of pipe with all thread going threw it install 1/2 inch nut to all thread. Voila home made bolt puller. Don't know may have already been done. might be worth trying. That would likely work, but the air chisel idea suggested above is much faster. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio@yahoo.com Link to comment Share on other sites More sharing options...
