Wrknrvr Posted June 13, 2018 Report Share Posted June 13, 2018 I am curious where one may find one of these locally. Or in another controller used on RVs. https://www.alliedelec.com/search/productview.aspx?SKU=70149708 This is just a picture, but I need one that is 3.15 amps 250 vac. I have a power gear leveling controller that has stoped retracting a rear jack. I talked to power gear and they say, and there service documents say to replace the fuse. So I never Sean a fuse as such or did not realize what it was. The customer would like it fixed a sap . So just wondering where one may find one . I have lots of RV boards laying around . But I even thought they may be in a CB radio.. Thanks. Vern Link to comment Share on other sites More sharing options...
Yarome Posted June 13, 2018 Report Share Posted June 13, 2018 A radial sub-mini you'll likely only lay hands on at an electronics supply store. Can't think of any RV appliance boards that might have one. Possibly out of a stand alone battery charger, a TV power adapter/power supply, lighting ballast... (?) It'll have to be a 120/240 device for any hope of finding one to rob. Might consider just "MacGyver'ing" a standard fuse holder onto the board to hold them over for a couple of days while you order one in. Link to comment Share on other sites More sharing options...
Sehc Posted June 13, 2018 Report Share Posted June 13, 2018 You don't say where local is local. I found many suppliers on-line. The most recognized is Granger, they may have a store near you. I searched 'Buss SR-5-3.15-BK' Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 13, 2018 Report Share Posted June 13, 2018 I've seen that style fuse in a cordless drill battery charger. I soldered an inline fuse holder in it's place, as a temporary fix. It's still there. There is a Grainger store in Billings. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Wrknrvr Posted June 13, 2018 Author Report Share Posted June 13, 2018 Thanks for all the good thoughts. If it was mine I would do something to fix it. But it is a customers , so should be done correctly. I did think of a appliance repair shop that I am going by today so will stop there. No Grainger in the local. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
Kirk W Posted June 13, 2018 Report Share Posted June 13, 2018 3 hours ago, Wrknrvr said: I did think of a appliance repair shop that I am going by today so will stop there. An appliance repair might have them as some microwave units do use such a fuse but I'm not sure of the value those are. I can't think of much else that I have seen those used in for appliances, but it is very possible that they might be there. Any good electronic supply house should be able to get them if not in stock. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 13, 2018 Report Share Posted June 13, 2018 Montana is similar to Canada, "local" is a rather open definition of geography. Just make sure the problem is resolved before smoking the replacement fuse. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted June 13, 2018 Report Share Posted June 13, 2018 https://www.digikey.com/products/en/circuit-protection/fuses/139?k=&pkeyword=&pv2088=u3.15A&FV=ffec3be4&quantity=0&ColumnSort=0&page=1&pageSize=25 Not quite but you do the leg work "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
Fulltimer51 Posted June 14, 2018 Report Share Posted June 14, 2018 I would want to know whats wrong with the unit that is causing the fuse to blow( If it is in fact blown). You may be spending a lot of time for a final fix only to find that you need more fuses during trouble shooting. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
Wrknrvr Posted June 16, 2018 Author Report Share Posted June 16, 2018 Customer is getting the fuse. Could not find it locally. It operates a coile to release pressure on a rear jack. Will keep informed. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
Wrknrvr Posted June 28, 2018 Author Report Share Posted June 28, 2018 I could not find one at a computer electronics repair shop. So I had the customer get some on the net. Installed one in the bad ones place. The jack system works as designed. Safe Travels,. Vern Link to comment Share on other sites More sharing options...
Kirk W Posted June 28, 2018 Report Share Posted June 28, 2018 3 minutes ago, Wrknrvr said: The jack system works as designed. Isn't success a great feeling! 👏 Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
