Gary Kidwell Posted June 27, 2018 Report Share Posted June 27, 2018 We have a 2015 Entegra Aspire. The dash air-conditioner stopped blowing cold air. I checked to see if the clutch was engaging after setting the control knob on dash to max AC, turned the temperature knob all the way to cold and turned the fan knob to high. The clutch engages for about two seconds and releases, about 20 seconds later the clutch engages again and releases. this process continued even after I sped the idle up with the cruise control. I would appreciate any advice. I am thinking the system might be low on freon. Link to comment Share on other sites More sharing options...
bob91yj Posted June 27, 2018 Report Share Posted June 27, 2018 Either low on freon or a bad pressure switch. Link to comment Share on other sites More sharing options...
Gary Kidwell Posted June 27, 2018 Author Report Share Posted June 27, 2018 Thank you for your help. I will check the freon pressure. If that does not fix the problem then it must be the pressure switch. Link to comment Share on other sites More sharing options...
Gary Kidwell Posted June 27, 2018 Author Report Share Posted June 27, 2018 How much pressure should there be on the low side Link to comment Share on other sites More sharing options...
jcussen Posted June 27, 2018 Report Share Posted June 27, 2018 http://rechargeac.com/how-to/ac-system-pressure-chart Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
Gary Kidwell Posted June 27, 2018 Author Report Share Posted June 27, 2018 Thanks again, I really appreciate your help. Link to comment Share on other sites More sharing options...
Gary Kidwell Posted June 28, 2018 Author Report Share Posted June 28, 2018 I added some freon, and the air conditioner started working just fine. Thanks again. Link to comment Share on other sites More sharing options...
