GlennWest Posted July 3, 2018 Report Share Posted July 3, 2018 Is there an antenna that could substitute s Batwing? Would like to remove it. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted July 3, 2018 Report Share Posted July 3, 2018 There are a few but why? The batwing, with the Wingman addition is one of the best available. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
chirakawa Posted July 3, 2018 Report Share Posted July 3, 2018 24 minutes ago, GlennWest said: Is there an antenna that could substitute s Batwing? Would like to remove it. I had the older style batwing, without the Wingman. I swapped it out for the King Jack, smaller and sleeker. I found that UHF stations came in a bit better. However, the VHF stations do not work near as well. The big, wide wings on a batwing are especially good at receiving VHF. Conclusion: add a Wingman to your older style batwing for best reception. Replace the batwing with a King Jack for a sleeker and smaller antenna with less performance. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
scouserl41 Posted July 3, 2018 Report Share Posted July 3, 2018 We replaced the dysfunctional batwing with the sleek King and regret having done so. The King picks up less channels than the plastic sheet antenna we've been using. The King was nearly $400 installed. The plastic antenna form Costco? $19!! BnB 2009 Monaco Cayman DP 38' bnbrv.blogspot.com/ Link to comment Share on other sites More sharing options...
GlennWest Posted July 3, 2018 Author Report Share Posted July 3, 2018 I want to remove from roof and relocate. Sorry wasn't clear on this. It will shade solar panels. Some kind of substitute 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Dutch_12078 Posted July 3, 2018 Report Share Posted July 3, 2018 The bottom line is that there are no roof mounted OTA antennas that will give equal or better performance than a Wingman equipped batwing. King makes a line of "Jack" directional and "Omni" omnidirectional roof mounted OTA antennas that are smaller and sleeker looking than the batwing, but do not offer the same level of performance, particularly on the low and high VHF channels, as the batwing. Those VHF channels are becoming more important now, as more stations are moving there from UHF due to the current UHF channel repack that's eliminating some high end UHF channels for TV service. Does the batwing really shade enough of your solar panels to make a significant difference in performance? Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
jcussen Posted July 3, 2018 Report Share Posted July 3, 2018 Had a Braun electric antenna on my coach and a tree branch removed it for me. My ceiling has fancy stuff on it, so could not drill a hole for the Jack or Winegard rotating antennas.So I tried this one https://www.pplmotorhomes.com/parts/entertainment-comfort-camping/tv-antennas-tv-satellites-electronics/antennas/rayzar-auto-over-air-antenna_22-0996?jt=1&jap=1o2&js=1&jsid=36859&jcpid=8a8ae4cd48005458014820e2e0170ec4&jkId=gcp:se_36859:pp_378367320183:ag_15211804824:cp_194253624:n_g:d_c:cr_52737673584&gclid=Cj0KCQjwvezZBRDkARIsADKQyPmmFRnfkWAlhTkEEXQQEzPYwsrF9Za8TnFOD8nlpxBncMIkjry-F6kaAlHYEALw_wcB Did not expect much, but was pleasantly surprised that it did pick up almost as many channels as my old directional UHF/VHF antennas. Most of the stations I get are about 35 miles away. Only need one wire [coax] from control panel inside. Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
Pat & Pete Posted July 3, 2018 Report Share Posted July 3, 2018 Why not just crank it half way down ? You'll likely get very close to the same amount of channels and only have early or late sun to worry about any shade . Maybe you're over thinking ? Are you gonna spend a dollar to save a nickle ? Goes around , comes around . Link to comment Share on other sites More sharing options...
GlennWest Posted July 3, 2018 Author Report Share Posted July 3, 2018 I may be over thinking it. Plan is, since roof acs going away, lots of room for solar. That will only item to shade. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rpsinc Posted July 3, 2018 Report Share Posted July 3, 2018 And IF it is the ONLY item to provide shade, it will be a small amount of shade and ONLY when the sun is in the right orientation, and ONLY for a short period of time. Yes, you are over thinking it. Marcel Link to comment Share on other sites More sharing options...
DKRITTER Posted July 9, 2018 Report Share Posted July 9, 2018 On 7/3/2018 at 12:16 PM, GlennWest said: I may be over thinking it. Plan is, since roof acs going away, lots of room for solar. That will only item to shade. I would think the batwing would cause little to no shade on a panel so the loss would be negligible. 2013 Newmar Dutchstar 4318 2019 F150 KR 4X4 BlueOx 10K Tow Bar Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 7, 2018 Report Share Posted August 7, 2018 The Winegard Sensar ( batwing) antenna with the Wingman ad-on is still one of the best for an RV. It is one of the few that elevates and height is a major factor in reception distance. The Wingman is needed to enhance UHF reception which most TV transmission has been moved to. There is nothing that makes a antenna special for HDTV, the frequencies are the same. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
chirakawa Posted August 7, 2018 Report Share Posted August 7, 2018 3 hours ago, Poetaso said: Hdtv antenna will do waay better than the batwing one. Check the article on the list of them the market provides And find a good one https://prizedreviews.com/best-outdoor-tv-antenna-for-hdtv/ . Wish you luck. There is no such thing as an Hdtv antenna. TV antennas are uhf/vhf and have been for 60 years or more. Most TV stations now broadcast on uhf, but some still broadcast on vhf, so you need both as you travel around the country. There is none better than the batwing for rv'ing. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 7, 2018 Report Share Posted August 7, 2018 I didn't see any directional antenna at the posted link that would be suitable for use on a mobile RV. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Ronbo Posted August 7, 2018 Report Share Posted August 7, 2018 We had the king jack and it was prone to catching tree branches. It was damaged and didn’t do a very good job of picking up stations even when new. I installed the razor air although I had to buy the one with the crank up assembly. When we use it, I am very happy with the signals it receives. It came with an amplifier that works great. You only need to install the new head and amplofier. https://www.rvrepairclub.com/video/rayzar-air-great-upgrade-to-your-standard-rv-antenna-007781/ Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 8, 2018 Report Share Posted August 8, 2018 According to Winegard, the Rayzar has poor high VHF (7-13) reception, and no low VHF (2-6) reception unless the tower is next door. The only good full spectrum RV OTA antennas are the Sensar III with an add-on Wingman or the Sensar IV with an integral Wingman. Both also have built-in amplifiers. Adding a SensarPro signal finder/in-line amplifier power injector replacement to either one boosts their performance even more. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
ms60ocb Posted August 8, 2018 Report Share Posted August 8, 2018 I just purchased an ANTOP UFO AT415B antenna for a fixed location. It sure beats anything I have ever tried and I hadn't taken it out side yet. Sure puts my Winegard Razor to shame. They claim some models are RV rated but I wouldn't want to add any more height to my already tall RV. The 414 series antenna may be the best for RV Mounting. They have better antennas but a rotor would be required. Clay Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
TXiceman Posted August 8, 2018 Report Share Posted August 8, 2018 Clay, good luck with the antenna. I am not a fan of any omnidirectional antenna. They perform equally bad in all directions. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 8, 2018 Report Share Posted August 8, 2018 The ANTOP UFO antenna is yet another example with poor to non-existent lo-VHF channel reception. Under the current in progress FCC mandated channel repack, there are 17 stations moving down to join the existing 43 lo-VHF channels, including stations in Boston, Los Angeles, and Pittsburgh. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
jcussen Posted August 8, 2018 Report Share Posted August 8, 2018 9 minutes ago, Dutch_12078 said: The ANTOP UFO antenna is yet another example with poor to non-existent lo-VHF channel reception. Under the current in progress FCC mandated channel repack, there are 17 stations moving down to join the existing 43 lo-VHF channels, including stations in Boston, Los Angeles, and Pittsburgh. http://dennysantennaservice.com/better-vhf-tv-reception-.html Agree, you just need the longer array for low VHF signals. Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
ms60ocb Posted August 9, 2018 Report Share Posted August 9, 2018 8 hours ago, Dutch_12078 said: Under the current in progress FCC mandated channel repack, there are 17 stations moving down to join the existing 43 lo-VHF channels, As far as I know I''m not impacted by the 17 channel move but I haven't seem the list or have I researched the 600 MHz spectrum sold last year. My present closest VHF channel to the fixed location I referred to would require a rotor and of no interest. Another seldom viewed channel is above 36 but wouldn't care if I lost it.. One fringe channel that was maybe 49 relocated a couple months but still in the UHF band. Channel 13 was picked by the ANTOP antenna when I did the little test a couple days ago. And last comment , the ANTOP antenna I have yet to run the cable, is primarily a local channel backup in event of satellite failure. Do you have a list of the channels that is converting back to VHF. My interest primarily is west of the Mississippi River. Thanks Clay Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 9, 2018 Report Share Posted August 9, 2018 I think most of us here are active/mobile RV'ers that visit various parts of the country at times, so having the full TV spectrum capability is likely more of interest than it would be to a fixed location/seasonal RV'er. Here's the most complete listing I'm aware of: https://www.rabbitears.info/repackchannels.php Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
ms60ocb Posted August 9, 2018 Report Share Posted August 9, 2018 Thanks for the quite impressive list List. Clay Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 9, 2018 Report Share Posted August 9, 2018 Note that while the list shows 152 stations going off the air, that's a bit misleading. While those stations are giving up their licenses, many will actually remain on the air as a sub-channel under another licensee. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 9, 2018 Report Share Posted August 9, 2018 Since the VHF band was taken for first responder use mainly because the VHF band has a longer range, I don't think there is much room for more VHF stations. They may be renumbering stations with the remap function. Most of the "VHF" band channels today are actually UHF remapped. I guess stations like low numbers for promotion. This was debated a lot back in the Digital TV transition. Digital TV is not necessary HDTV but it is how all TV in the US is transmitted. At the time, over 50% of US households received their TV via cable or satellite. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
