Bill Downing Posted August 6, 2018 Report Share Posted August 6, 2018 My sewer line has accumulated a pink, red, purple slime on the inside. What is it and how do I get rid of it? Thanks in advance. Link to comment Share on other sites More sharing options...
Barbaraok Posted August 6, 2018 Report Share Posted August 6, 2018 Mold/algae. Rinse better after use. Let it dry out, ie dump afternoon before leaving but don’t take down to store until morning. Other things to try, run black tank through., dump gallon of vinegar in toilet and flush, the run Grey tank out, dump another gallon down sink put some more water, then rinse hose with lots of water. Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
D&J Posted August 7, 2018 Report Share Posted August 7, 2018 If you are sitting hooked up for a extended period with the grey valve open that will happen, its easy to slush out with a water hose. Denny Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
Five Wood Posted August 7, 2018 Report Share Posted August 7, 2018 You put some plastic gloves on and rinse your sewer line with fresh water. It's really not that difficult. Jim JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
Kirk W Posted August 7, 2018 Report Share Posted August 7, 2018 Welcome to the Escapee forums! Always happy to have new folks join us here. I really don't have much to add but was wondering if you are hooked up and sitting in one spot and leaving the line connected all of the time? In my experience that is when one is most likely to experience growing things in the sewer hose. Several of those suggestions I would make too. I'm not sure that you have anything to worry about but it is good to clean the hose from time to time while sitting still and allow it to dry out occasionally too. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
remoandiris Posted August 7, 2018 Report Share Posted August 7, 2018 Just curious as to why you care about slime build up in the waste line. Is the slime restricting the flow or something? Is there an odor backing up into the coach? Link to comment Share on other sites More sharing options...
FL-JOE Posted August 8, 2018 Report Share Posted August 8, 2018 We have 3 different locations (parks) where we will sit in the same site for a month or so. My clear sewer elbows and my stinky-slinky will get a slight build up and not stay perfectly clean no matter how much I rinse while hooked up. About 2 or 3 times a year I will mix up a bucket of Dawn and bleach water and get to work cleaning it all. I let the mixture sit in the sections of stinky-slinky by connecting the ends together. After it sits for an hour or so and I shake it around a little I dump it all out and rinse really good. I let the sections dry in the sun and then coat them with 303 on the outside. Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
richfaa Posted August 8, 2018 Report Share Posted August 8, 2018 What FL-JOE says. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
