Jimfdoc Posted August 7, 2018 Report Share Posted August 7, 2018 Heard a pop, then one side of electrical outlets would not work, other side is fine what can cause this Link to comment Share on other sites More sharing options...
Optimistic Paranoid Posted August 7, 2018 Report Share Posted August 7, 2018 Most probably, the two sides are on different circuit breakers, and that 'pop' was the sound of one of your circuit breakers opening. Regards John DON'T FEED THE VULTURES! My Body is a Temple! Ancient, Crumbling, Probably Cursed . . . I Don't Like to Make Advanced Plans. They Cause the Word "PREMEDITATED" to Get Thrown Around in Court! Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 7, 2018 Report Share Posted August 7, 2018 4 minutes ago, Optimistic Paranoid said: Most probably, the two sides are on different circuit breakers, and that 'pop' was the sound of one of your circuit breakers opening. Hopefully that's all it was . I have to wonder exactly what might have made that happen . Goes around , comes around . Link to comment Share on other sites More sharing options...
Kirk W Posted August 7, 2018 Report Share Posted August 7, 2018 2 hours ago, Jimfdoc said: Heard a pop, then one side of electrical outlets would not work, other side is fine what can cause this It could have been a circuit breaker, or it could have also been a GFCI outlet that tripped. If you find it and reset it, the breaker must be opened fully, then reclosed to properly reset it. The GFCI has a separate reset button. circuit breaker GFCI outlet Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
oldjohnt Posted August 7, 2018 Report Share Posted August 7, 2018 While such a noise and result could be due to a tripped breaker or GFCI, I've seen a loose/burned/resistive connection make an arc and noise yielding the same result, so check breakers and connections for evidence of heat and burning. John T Link to comment Share on other sites More sharing options...
