GlennWest Posted August 7, 2018 Report Share Posted August 7, 2018 My Teton has a trim that molds badly. Also is shrinking. Pulling away at corners. Really believe orginal owner replaced it with inferior trim. Considering replacing. Really hurts appearance. What would you guys recommend. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 7, 2018 Report Share Posted August 7, 2018 Glenn , Post a pic of the trim you're talking about . Goes around , comes around . Link to comment Share on other sites More sharing options...
GlennWest Posted August 7, 2018 Author Report Share Posted August 7, 2018 I will later. At work sheltering in tent from storm. It is trim that fits in a channel that goes around door and a flatter one that separates gelcoat from aluminum bottom. It is soft like vinal. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 7, 2018 Report Share Posted August 7, 2018 If the channel is about 5/8 - 3/4" wide and pretty shallow , I think you might be talking about the 'bump' trim that covers the screws . I replaced all that covering on our Monaco . The original was so ingrained with years of dirt and such , the only way to make it look decent would have been to scrape a layer off . Anyway , the OEM stuff was a lot thicker and definitely of better quality than what I found and used . But , it's just a cover and doesn't need to be HD . The new stuff I put on looks just as good as OEM and it's clean . Goes around , comes around . Link to comment Share on other sites More sharing options...
GlennWest Posted August 7, 2018 Author Report Share Posted August 7, 2018 That's it. Mine bout an inch wide. Ok. I had never remembered anyone posting about replacing it. Thanks 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 7, 2018 Report Share Posted August 7, 2018 4 hours ago, GlennWest said: That's it. Mine bout an inch wide. Ok. I had never remembered anyone posting about replacing it. Thanks Take a look at the pics on this page . They show the difference . I figured the stuff is cheap enough and easy enough to install that even if it only lasted a few years it was worth it . https://www.etrailer.com/RV-Exterior/Camco/CAM25202.html?feed=npn&gclid=CjwKCAjwhqXbBRAREiwAucoo-x87ujv0YD7OcAaHQHhde_aNKl1z2MI0g91lOjIhAkjy0mVmR1RrAhoCbLcQAvD_BwE Goes around , comes around . Link to comment Share on other sites More sharing options...
