tsothermail Posted August 31, 2018 Report Share Posted August 31, 2018 Has anyone setup the use of a c-pap machine to work off the battery? if so how did you do it? Link to comment Share on other sites More sharing options...
Kirk W Posted August 31, 2018 Report Share Posted August 31, 2018 Our son is a Scout Master who uses a c-pap machine and his is 12V and operates from a battery or a 12V outlet. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
KnoxSwift Posted August 31, 2018 Report Share Posted August 31, 2018 I have had to support both a 12v and a 24v. 12V is pretty easy obtain a car adapter and don't run the humidifier. 24v there are two ways. 1. Buy a 24v batter and charge it as you drive. there is a 12v to 24v adaptor for some models of C-PAPs. However with this it will draw quite a few amps. You'll also have to run without humidifier on battery or on adapter. Link to comment Share on other sites More sharing options...
remoandiris Posted September 1, 2018 Report Share Posted September 1, 2018 4 hours ago, tsothermail said: Has anyone setup the use of a c-pap machine to work off the battery? if so how did you do it? Are you asking if anyone has routed wires from their bedroom to their RV's battery box or other RV 12v connection? Or are you asking if anyone has a 12v battery in their bedroom to connect a cpap to? If the latter, there are 12v adapters available. If the former, not that I've read on the forum, but that doesn't mean it hasn't been done. Link to comment Share on other sites More sharing options...
ms60ocb Posted September 1, 2018 Report Share Posted September 1, 2018 5 hours ago, tsothermail said: Has anyone setup the use of a c-pap machine to work off the battery? if so how did you do it? My C-Pap requires 12v so I purchased a 12v to 12v adapter cable on line than a wire from the fuse panel to the bed area. For my present Fifth Wheel, I ordered a 12v outlet installed in the bed area. A direct DC connection is much more more efficient than having an invertor to supply 120 vac to the C-pap. If your question is now finding the power requirements, start by looking at the spec's for the unit or talk to your supplier. Clay Clay & Marcie Too old to play in the snow Diesel pusher and previously 2 FW and small Class C Link to comment Share on other sites More sharing options...
Jim Corey Posted September 1, 2018 Report Share Posted September 1, 2018 I have an inverter outlet in my bedroom. When dry camping, I use that. I move the plug to a 110v outlet when we have hookups. Easy Peasy. CPap doesn’t seem to draw all that much. Jim Corey 2006 Monaco Monarch 30 pdd '12 Honda CRV toad Link to comment Share on other sites More sharing options...
