dosbeagles Posted September 9, 2018 Report Share Posted September 9, 2018 I am trying to figure out how a manufacturer determines the GVWR. Is it the sum of the axle weight ratings and the pin weight or is there some other mysterious formula? Thanks in advance for your help. Chris & Joni The Beagles now 3 Daphne, Ace and Flash looking 2016 Acura MDX http://jnctravelogue.wordpress.com Link to comment Share on other sites More sharing options...
Big5er Posted September 9, 2018 Report Share Posted September 9, 2018 Interesting read here but here is a different view MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Al F Posted September 9, 2018 Report Share Posted September 9, 2018 15 hours ago, dosbeagles said: I am trying to figure out how a manufacturer determines the GVWR. Is it the sum of the axle weight ratings and the pin weight or is there some other mysterious formula? Thanks in advance for your help. If you are asking because you are going to build a trailer, Big5er has your answer. If are you just want to know how most trailer RV's come up with the GVWR, it usually is the gross axle weight plus the hitch weight. That is why you see trailers with a 2 axle setup of 7000 pounds each coming up with a GVWR of around 16,000-17,000 pounds. 14,000 for axle and 2000-3000 for hitch. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
dosbeagles Posted September 9, 2018 Author Report Share Posted September 9, 2018 16 hours ago, Big5er said: Interesting read here but here is a different view Thank you. Interesting article. Chris & Joni The Beagles now 3 Daphne, Ace and Flash looking 2016 Acura MDX http://jnctravelogue.wordpress.com Link to comment Share on other sites More sharing options...
dosbeagles Posted September 9, 2018 Author Report Share Posted September 9, 2018 1 hour ago, Al F said: If you are asking because you are going to build a trailer, Big5er has your answer. If are you just want to know how most trailer RV's come up with the GVWR, it usually is the gross axle weight plus the hitch weight. That is why you see trailers with a 2 axle setup of 7000 pounds each coming up with a GVWR of around 16,000-17,000 pounds. 14,000 for axle and 2000-3000 for hitch. This is what I had kinda figured but wanted to make sure my thinking was correct. Chris & Joni The Beagles now 3 Daphne, Ace and Flash looking 2016 Acura MDX http://jnctravelogue.wordpress.com Link to comment Share on other sites More sharing options...
