jdhm Posted October 15, 2018 Report Share Posted October 15, 2018 Help. Kitchen sink wonk drain. Checked pipes under dink. All clear. Used a lot of baking soda and vinegar. Used plunger. Nothing helps. Any suggestions? Thank you. J.D. Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 15, 2018 Report Share Posted October 15, 2018 First of all I am not a chemist so with what you have in there now mite be a proble with my idea. I have used simple green to clear a drain. Is there any flow at all. If you fill the sink to the bottom will it drain. Even over 12 hours. At all. The simple green may take overnight to do its thing. If not it may be time to use a plumbers snake to clear it. just my thoughts Vern Link to comment Share on other sites More sharing options...
oldjohnt Posted October 15, 2018 Report Share Posted October 15, 2018 I am concerned about any over harsh chemical drain cleaners in my RV drain pipes and holding tanks etc., so if a clog persists despite your efforts Id be looking at a snake type cleaning BUT IM NOOOOOOOOOO PLUMBER. My advice is ask a professional plumber about this and/or try using a snake yourself which I don't view as any big risk and would certainly try myself. Sorry no help, only a non professional opinion. John T Link to comment Share on other sites More sharing options...
Superchief48 Posted October 15, 2018 Report Share Posted October 15, 2018 I am new to this site and would like to start a new topic. What is meant by "title" and" tags? Link to comment Share on other sites More sharing options...
Kirk W Posted October 15, 2018 Report Share Posted October 15, 2018 5 minutes ago, Superchief48 said: I am new to this site and would like to start a new topic. What is meant by "title" and" tags? Let me suggest that you make a new post that starts a new thread in the beginner's forum since this one is about plumbing problems. 7 hours ago, jdhm said: Checked pipes under dink. All clear. Would I be correct to assume that you have taken the drain trap apart and cleaned it out? Is your kitchen sink split into a double sink and if so, are both sides clogged up? If you have not taken off the drain trap I would start with that. It is usually pretty easy to remove and then just take it outside and push something through it and use detergents and hot water to clean it completely. If you are able to get at least a small amount to pass through the drains you can then use other means to clean the piping but if nothing at all goes through you will have to use a plumber's snake or remove the drain piping. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Optimistic Paranoid Posted October 15, 2018 Report Share Posted October 15, 2018 The original poster didn't say anything about the condition of the gray tank. Are we assuming that it isn't full? Regards John DON'T FEED THE VULTURES! My Body is a Temple! Ancient, Crumbling, Probably Cursed . . . I Don't Like to Make Advanced Plans. They Cause the Word "PREMEDITATED" to Get Thrown Around in Court! Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 15, 2018 Report Share Posted October 15, 2018 Is it a double ( side by side ) sink ? If so , when you plunge , are you blocking the drain not being plunged so all pressure is being forced down the pipe rather than out the other drain hole ? Goes around , comes around . Link to comment Share on other sites More sharing options...
jpcoll01 Posted October 15, 2018 Report Share Posted October 15, 2018 Good suggestions above. Easiest solution would be that your grey tank is full and your "lights" are just goofed up showing that it isn't full (happens all the time). but if it drained enough to let you check the traps then maybe that isn't the case. Shouldn't be a very long run and woudl be easy to run a cheap snake down the line after taking off the trap and ensure a clear run to your grey tank. Should be able to get one at Lowes for under $20. Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 15, 2018 Report Share Posted October 15, 2018 40 minutes ago, jpcoll01 said: Good suggestions above. Easiest solution would be that your grey tank is full and your "lights" are just goofed up showing that it isn't full (happens all the time). but if it drained enough to let you check the traps then maybe that isn't the case. Shouldn't be a very long run and woudl be easy to run a cheap snake down the line after taking off the trap and ensure a clear run to your grey tank. Should be able to get one at Lowes for under $20. Maybe that^ only if the kitchen sink has a separate grey tank . If the grey is shared with the bathroom sink and shower , the kitchen sink water , being higher , would tend to come up in the shower if the grey was full . Goes around , comes around . Link to comment Share on other sites More sharing options...
Optimistic Paranoid Posted October 15, 2018 Report Share Posted October 15, 2018 13 minutes ago, Pat & Pete said: Maybe that^ only if the kitchen sink has a separate grey tank . If the grey is shared with the bathroom sink and shower , the kitchen sink water , being higher , would tend to come up in the shower if the grey was full . Hmnn. A valid point. But not every rig has a shower and bathroom sink. Alaskan truck campers don't. Regards John DON'T FEED THE VULTURES! My Body is a Temple! Ancient, Crumbling, Probably Cursed . . . I Don't Like to Make Advanced Plans. They Cause the Word "PREMEDITATED" to Get Thrown Around in Court! Link to comment Share on other sites More sharing options...
jdhm Posted October 15, 2018 Author Report Share Posted October 15, 2018 Thank you for your suggestions. Plumbing under sink was removed and is clear. Gray tank empty and open. Having a professional look at it this afternoon. Thanks J.D. Link to comment Share on other sites More sharing options...
Barbaraok Posted October 15, 2018 Report Share Posted October 15, 2018 Did you pour some boiling water down the drain? Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Kirk W Posted October 15, 2018 Report Share Posted October 15, 2018 3 hours ago, jdhm said: Having a professional look at it this afternoon. If you would, please post a summary of what your professional finds to be the problem so that we may learn from it. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted October 15, 2018 Report Share Posted October 15, 2018 I would think the vacuum breaker is stuck closed. An easy fix after a trip to Lowes, Home Depot, etc. 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
Kirk W Posted October 15, 2018 Report Share Posted October 15, 2018 7 minutes ago, GeorgiaHybrid said: I would think the vacuum breaker is stuck closed. An easy fix after a trip to Lowes, Home Depot, etc. That is a possibility nobody has mentioned. Not sure it would totally block but it sure can make things slow. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
jdhm Posted October 15, 2018 Author Report Share Posted October 15, 2018 What and where is the vacuum breaker? Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted October 15, 2018 Report Share Posted October 15, 2018 It is under the sink and under a vacuum it will open to allow air to pass and water to drain and will be above the P trap. They cost about 8 to 15 dollars at any home improvement store 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
Kirk W Posted October 16, 2018 Report Share Posted October 16, 2018 4 hours ago, jdhm said: What and where is the vacuum breaker? There are several types and you should have one located under each sink in the RV and up near the counter top that it sits on. Here is a picture of what is under out sink. whi That is the subject vent to the upper right. They are readily available from Lowe's and Home Depot as well as on Amazon. Those like the one shown here cost less than $10 and usually fail every few years. If they fail closed it causes drain problems, fail open which is more common and it lets sewer odors into the RV. A higher quality one that also costs about double is shown below. As a quick test to see if this is your problem, just unscrew the vent and take it out of the system and see if that makes the problem go away. If it does not solve the problem this isn't the cause. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
jdhm Posted October 17, 2018 Author Report Share Posted October 17, 2018 Vent was replaced. Did not help. Link to comment Share on other sites More sharing options...
jpcoll01 Posted October 17, 2018 Report Share Posted October 17, 2018 Snake from under the sink. Link to comment Share on other sites More sharing options...
jdhm Posted October 17, 2018 Author Report Share Posted October 17, 2018 Before I put new vent on I ran water into sink. It can out the pipe the vent screws into. Could that pipe be clogged? Link to comment Share on other sites More sharing options...
jdhm Posted October 17, 2018 Author Report Share Posted October 17, 2018 Also, rv repair place said it might be the lining of the pvc pipe can loose and is causing the problem. Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 17, 2018 Report Share Posted October 17, 2018 PVC has a lining ??? Goes around , comes around . Link to comment Share on other sites More sharing options...
Kirk W Posted October 17, 2018 Report Share Posted October 17, 2018 3 hours ago, jdhm said: Before I put new vent on I ran water into sink. It can out the pipe the vent screws into. Could that pipe be clogged? That is what it sounds like to me. Like Pete, I question the lining thing. If it were me, I would never go near that guy if I needed service. I have used a lot of PVC piping in various places even installing water hydrants and as part of a volunteer work crew with major plumbing projects. I have never seen any sort of PVC pipe that has a lining. Second, all RV drain plumbing that I have ever seen is not PVC but is really ABS, which is the black pipe that I am sure you found under the sink where that plumbing vent was located. Have you removed the "P" trap and taken it out and cleaned it? That is the place that I have found to be the most probably for a plug to occur. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Chad Heiser Posted October 18, 2018 Report Share Posted October 18, 2018 The RV repair guy may be referring to a HepvO valve and the "lining" in them. HepvO valves are used in many RV's in place of traps due to limited space under RV sinks/cabinets. Here is a document explaining the differences between HepvO installations and typical trap installations in RV's. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
