palmeris Posted June 27, 2019 Report Share Posted June 27, 2019 Hello about 108k and time to replace the factory shocks- all stock, has the off road package( shields underneath) and towing package, factory puck system. looking for suggestions, are the rancho the way to go, are the bilstein or others any better? Most of those miles were every day highway non towing, probaly just 20 k doing conventional towing with an 8 k load. In a few years looking to adding a comfort ride hitch for a fifth wheel, heavy set up in the 20-22 k range and 20% pin basically what the truck was made to do. But will still be some non towing highway trips, some no loads, some aforementioned 8 k conventionals trailer runs etc. Have the money now to do some upgrades, or at lease get ready for the future loads so looking for suggestions, maybe something thats adjustable... maybe consider changing out coils to air bags... dont know much about air suspension , compressors, tanks etc but like the idea of having a compressor not only for suspension but air horns, tire inflation, etc so any suggestions are appreciated. Im fairly handy with tools, have a wide varity of wrenchs, sockets, impact and the like , its just my body that may protest a bit....oh and also going to change out the tank to the titan to up capaicity to 65 gallon Thanks in advnace for any input Link to comment Share on other sites More sharing options...
TXiceman Posted June 27, 2019 Report Share Posted June 27, 2019 I put a set of Ranchos on my F350 DRW and they were JUNK....lasted about 30,000 miles. Replaced with KYB's and they are doing better. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted June 27, 2019 Report Share Posted June 27, 2019 Bilsteins ! Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
palmeris Posted June 28, 2019 Author Report Share Posted June 28, 2019 Anyone running fox 2.0 ? - From what i see they are adjustable and serviceable. high $ but the last shocks you ever put on, just have to get them "serviced" every 50k... wonder if anyone has any history towing 5th wheel with them. Thinking of the adjustable on the rear and the ifp non adjust on the front https://www.ridefox.com/filter.php?f1=&v1=&m=truck&make=Ford&model=F-450+Super+Duty+Crew+Cab+Pickup&year=2014&position=ALL Link to comment Share on other sites More sharing options...
noteven Posted June 30, 2019 Report Share Posted June 30, 2019 Hi palmeris F450 air ride thread from RV.net truck campers forum. I had poor life and service from a set of Rancho 9000 2 leaking before 12K miles. Warranty was not worth the fight so I installed Bilsteins. I contacted them for the correct model / part number for my application- truck camper on won ton. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
palmeris Posted July 4, 2019 Author Report Share Posted July 4, 2019 I ordered the fox 2.0 units, should be here next week Link to comment Share on other sites More sharing options...
palmeris Posted July 16, 2019 Author Report Share Posted July 16, 2019 So I installed the fox 2.0 ifp front shocks and steering stabilizer along with the adjustable resivor 2.0 ifp shocks for the rear over the weekend. Was able to use my air compressor and impact wrench for all but the upper front mounts as it wouldn't fit in the space. Took about three hours as it was hot as hell out and I took a few hydration breaks Put truck on ramps so lots of space for me underneath, used a ratchet strap to compress the new front shocks and a floor jack to compress the rear ones which made installing easy without having the weight off the axles. Did test drives,started out with the rear adjustable at 1, which is basically zero resistant, ending with it set at 3 which seems perfectly firm for no weight load in the truck other than me and fuel. Testing on some local streets speed bumbs and 200 miles of highway Setting go up to 8 so will check those upper levels out once we get towing or some weight load in the bed. I can just reach in over the dually wheels and access the rotary knob on the resivor to adjust, so super easy to adjust. Glad I did it, frankly the stock ones were over due for replacement I usually change them out whenever I put on new tires but at 80 k they told me shocks were still good...they were all shot at 107k that's for sure..go forward its recommendation by fox for shocks to be serviced at 50k intervals Next up is a set of air bags for the rear, the air lift ultimate plus with internal jounce bumpers and stainless steel lines and roll plates should be here by end of the week. Link to comment Share on other sites More sharing options...
palmeris Posted August 15, 2019 Author Report Share Posted August 15, 2019 So still havent done the air bags, they are sitting on the bench ready to go in, just been to damn hot out to crawl under to do it. So while Im waiting for a break in the south florida heat I had the body mounts replaced with Silicone mounts from S&B and a 65 gallon XXL replacement tank installed, all done by my local dealer and they changed the program for the new fuel capacity. I supplied the mounts and tanks, they did the labor. Saw how bad the mounts were when I was under there doing the shocks, after just 5 years and 110k miles they were crumbling, at least 3 were completely shot. I could hear and feel the body move when making grade changes like pulling in a drive way - not any more. nice and tite now.. Link to comment Share on other sites More sharing options...
