tworootless Posted September 10, 2019 Report Share Posted September 10, 2019 Hi all Not at all familiar with the Diesel fired Hurricane heating system. All seems to work when switched on, no codes off circuit board. Although, it takes a several minutes before any heat comes from the vents. Is this normal for those that are familiar with this system. Thanks BD Link to comment Share on other sites More sharing options...
jcussen Posted September 10, 2019 Report Share Posted September 10, 2019 Depends on your coach, if it is an diesel fired air system, right away but if hydronic, meaning it heats water and circulates through heat exchangers, will take a while to get up to temp. Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
