Cindy F. Posted September 20, 2019 Report Share Posted September 20, 2019 While driving on I-95, our 2018 Dutchmen Aspen Trail's roof was billowing near the front of the trailer. I looked like a huge pillow on top of the roof. Has this happened to anyone? What is the cause and what needs to be done to fix it? Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted September 21, 2019 Report Share Posted September 21, 2019 (edited) Dicor has a remedy, which may be read at: https://dicorproducts.com/faq/#petroleum-distillates If you desire a specific answer to your issue, there is a place to ask it on the Dicor website, it's called "ask Rudy".. The most common cause is someone using a product containing petroleum distillates on the EPDM material. That webpage tells you how to identify this. That may not be the cause though, another cause is the EPDM material being laid before the glue is ready. Edited September 21, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 21, 2019 Report Share Posted September 21, 2019 The glue bonding the roof membrane to the underlay has let go. You have two choices; inject glue through the roof membrane, then re-seal it, or live with the balloon. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Kirk W Posted September 21, 2019 Report Share Posted September 21, 2019 10 hours ago, Darryl&Rita said: The glue bonding the roof membrane to the underlay has let go. You have two choices; inject glue through the roof membrane, then re-seal it, or live with the balloon. You can probably get access to the space under the material from the front of the trailer and use something to spreat the glue back well under the material or you could cut the material and then repair the cut once it is glued back in place. You need to make sure that you use the proper glue to put it back and the same with the repari of any cut you make. I would not use live with that problem as it will likely get worse and in time tear away while traveling at highway speeds. The problem could be caused either by products that have been used on the roof or it may have gotten moisture between the membrane and the underlay. I would want to investigate the cuase of this problem as part of the repair. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
SnowGypsy Posted September 21, 2019 Report Share Posted September 21, 2019 I would be concerned that air is getting in there to puff it up like that. If air gets in, water can get it also. I would call Dutchmen customer service, especially if I purchased this new or even otherwise to see what they suggested I do. This is a giant bubble, not the standard bubbles, and I would make sure that was understood. This is not "normal". I once read a post where a family was cruising down the highway on vacation and suddenly saw their roof peeling off, so I wouldn't ignore it. We had an entry level TT from the worst of manufacturers and never had a problem like this with the rubber roof in the 5 years we owned it, so I would be very firm with the manufacturer about my displeasure with the situation. If the manufacturer chooses to ignore it, Dicor may be able to advise, but I would still make the manufacturer aware that their 2018 product in less than 2 years was requiring repairs most likely due to the way the roof was installed unless it has in some way been abused. Quote Cathy Link to comment Share on other sites More sharing options...
chirakawa Posted September 21, 2019 Report Share Posted September 21, 2019 I would definitely get a new roof. There's a good chance that water had seeped under the rubber/vinyl and dissolved the water based glue. If so, you may find water damage when you peel off the roof material. In any case, if you didn't have water under there before, you will have in the future if you don't repair/replace the roof. I wouldn't "live with" it. Quote Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 17 hours ago, Ray,IN said: Dicor has a remedy, which may be read at: https://dicorproducts.com/faq/#petroleum-distillates If you desire a specific answer to your issue, there is a place to ask it on the Dicor website, it's called "ask Rudy".. The most common cause is someone using a product containing petroleum distillates on the EPDM material. That webpage tells you how to identify this. That may not be the cause though, another cause is the EPDM material being laid before the glue is ready. I sent an email to Rudy last night. Hope to hear from him soon. Quote Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 17 hours ago, Darryl&Rita said: The glue bonding the roof membrane to the underlay has let go. You have two choices; inject glue through the roof membrane, then re-seal it, or live with the balloon. I am not sure if we have a rubber roof (Dicor) or an Alpha Superflex TPO roof as both are listed in the Dutchmen owner’s manual. Quote Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 7 hours ago, Kirk W said: You can probably get access to the space under the material from the front of the trailer and use something to spreat the glue back well under the material or you could cut the material and then repair the cut once it is glued back in place. You need to make sure that you use the proper glue to put it back and the same with the repari of any cut you make. I would not use live with that problem as it will likely get worse and in time tear away while traveling at highway speeds. The problem could be caused either by products that have been used on the roof or it may have gotten moisture between the membrane and the underlay. I would want to investigate the cuase of this problem as part of the repair. It did rain a couple of days while we were traveling and there was a leak right over the bed. Fortunately, we had good weather the rest of the trip. We tarped it due to Hurricane Dorian and still is tarped. I think there was inferior glue placed from the onset. Did I mention it had to be completely rewired in 2018? In the shop for 3 months! Quote Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 5 hours ago, SnowGypsy said: I would be concerned that air is getting in there to puff it up like that. If air gets in, water can get it also. I would call Dutchmen customer service, especially if I purchased this new or even otherwise to see what they suggested I do. This is a giant bubble, not the standard bubbles, and I would make sure that was understood. This is not "normal". I once read a post where a family was cruising down the highway on vacation and suddenly saw their roof peeling off, so I wouldn't ignore it. We had an entry level TT from the worst of manufacturers and never had a problem like this with the rubber roof in the 5 years we owned it, so I would be very firm with the manufacturer about my displeasure with the situation. If the manufacturer chooses to ignore it, Dicor may be able to advise, but I would still make the manufacturer aware that their 2018 product in less than 2 years was requiring repairs most likely due to the way the roof was installed unless it has in some way been abused. I called Dutchmen a few days ago and was pointed to the dealer (La Mesa R.V. in Sanford). They said it wasn’t under warranty anymore and to bring it in for a diagnostic for $150. I left a message with Dutchmen customer service today and hope to hear from them the next business day. The roof has not been abused. It sits in an opened area and doesn’t have any trees over it. Quote Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 4 hours ago, chirakawa said: I would definitely get a new roof. There's a good chance that water had seeped under the rubber/vinyl and dissolved the water based glue. If so, you may find water damage when you peel off the roof material. In any case, if you didn't have water under there before, you will have in the future if you don't repair/replace the roof. I wouldn't "live with" it. Something will have to be done because we can’t use it as is. It is just a matter of who is responsible and who is going to fix it!! Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted September 21, 2019 Report Share Posted September 21, 2019 (edited) FWIW, The Dutchmen factory service center in N. Indiana does excellent work. We took our Grand Junction 5er there for repair to a slide mechanism. They found a bent arm, and replaced the entire assembly at no charge to us. The service center manager said it was a factory defect. Our 5er was 3 yrs old at the time. They have electric only parking spots available outside the factory. We stayed overnight in our 5er, and early next morning they took it inside for repairs/replacements. Edited September 21, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 21 minutes ago, Ray,IN said: FWIW, The Dutchmen factory service center in N. Indiana does excellent work. We took our Grand Junction 5er there for repair to a slide mechanism. They found a bent arm, and replaced the entire assembly at no charge to us. The service center manager said it was a factory defect. Our 5er was 3 yrs old at the time. They have electric only parking spots available outside the factory. We stayed overnight in our 5er, and early next morning they took it inside for repairs/replacements. Unfortunately, I don't think we could take it safely to Indiana from Florida. The photos show our temporary fixes. My husband put a strap on the roof to start with until we got to the campground. Then he removed the old caulk and the original bar in the front. Next, he put the rubber roof under the lip, put the original bar back on, put a 2" steel bar next to it, and used Dicor caulk to spread all over that area. That held it for a day, but even with the strap the bubble appeared again. Lastly, he made a "constraption" out of plastic lattice work, a treated wood brace and 2 straps that went around the entire trailer. This held the bubble down as we traveled back to Florida. 20190825_122621640_iOS - Shortcut.lnk 20190825_131633370_iOS - Shortcut.lnk 20190825_180545938_iOS - Shortcut.lnk 20190827_145728695_iOS - Shortcut.lnk 20190827_200910826_iOS - Shortcut.lnk Quote Link to comment Share on other sites More sharing options...
2gypsies Posted September 21, 2019 Report Share Posted September 21, 2019 Wow! What a mess to deal with! So sorry. As we drove on highways we have seen others do this and commented that the whole roof could be torn off while driving. Most people probably don't even know that theirs does that. Good thing you caught it but sounds like a difficult fix by yourselves. Hopefully, you can find someone to fix it. Quote Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 (edited) I’m not sure the photos will open. Edited September 22, 2019 by Cindy F. Quote Link to comment Share on other sites More sharing options...
Cindy F. Posted September 21, 2019 Author Report Share Posted September 21, 2019 8 minutes ago, 2gypsies said: Wow! What a mess to deal with! So sorry. As we drove on highways we have seen others do this and commented that the whole roof could be torn off while driving. Most people probably don't even know that theirs does that. Good thing you caught it but sounds like a difficult fix by yourselves. Hopefully, you can find someone to fix it. I am hoping there will be a resolution on Dutchmen’s part. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 22, 2019 Report Share Posted September 22, 2019 2 hours ago, Cindy F. said: I’m not sure the photos will open. They do not. You must have them somewhere on the internet for us to see them. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Cindy F. Posted September 22, 2019 Author Report Share Posted September 22, 2019 (edited) 1 hour ago, Kirk W said: They do not. You must have them somewhere on the internet for us to see them. Edited September 22, 2019 by Cindy F. Quote Link to comment Share on other sites More sharing options...
Cindy F. Posted September 22, 2019 Author Report Share Posted September 22, 2019 This was the temporary fix. The Constraption! I wasn't successful in posting the other photos. Possibly too big. Might try later. Quote Link to comment Share on other sites More sharing options...
Lance A Lott Posted September 22, 2019 Report Share Posted September 22, 2019 Try this for pictures. http://photoposting.is-great.net/?i=1 Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 22, 2019 Report Share Posted September 22, 2019 9 hours ago, Cindy F. said: This was the temporary fix. Looks like a good approach. Hope it all works out. I don't know if it has changed but the glue that they use was water soluable in the early days so a roof leak may have played a part in this. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 22, 2019 Report Share Posted September 22, 2019 Around 8-10 years ago, a major manufacturer had a QA/QC issue with supplied materials that resulted in lots and lots of bubble roofs. It turned out the glue had been frozen in shipment, at some point. The dealerships were flooded with warranty work To the point, the triage involved leaking vs. not leaking. Leakers got in sooner. All the units were handled, eventually. I mistakenly thought the OP was on a vacation trip, that's why I said live with it. With the addition of leaks, it needs to be fixed sooner. For those wondering, this is an example of aerodynamics. Low pressure air is sucking up the roof membrane, not high pressure air getting underneath and forcing it up. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
chirakawa Posted September 22, 2019 Report Share Posted September 22, 2019 3 minutes ago, Darryl&Rita said: For those wondering, this is an example of aerodynamics. Low pressure air is sucking up the roof membrane, not high pressure air getting underneath and forcing it up. In order for low pressure to be "sucking" up the roofing, there has to be high pressure underneath the membrane. If it was properly adhered to the roof, it wouldn't happen. Otherwise, all roofs would go down the highway in a bubble. So, yes, there is air getting under the membrane.....................which means a leak. On an airplane wing, pressure is removed from the top of the wing and higher pressure pushes up on the bottom of the wing, called lift. So, it is high pressure forcing it up. Quote Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 22, 2019 Report Share Posted September 22, 2019 I'm done. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Kirk W Posted September 22, 2019 Report Share Posted September 22, 2019 6 hours ago, Darryl&Rita said: I'm done. 😊😁 Agreed. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
