Imoski Posted October 26, 2019 Report Share Posted October 26, 2019 The story so far... Landing gear came worked fine this morning (extended to hitch to truck; retracted for storage) At new campsite tonight they won't extend but will retract. I got them down manually with the handle to stabilize the 5th wheel for tonight. Any ideas why they go up but not down? Thanks! Quote Link to comment Share on other sites More sharing options...
Ronbo Posted October 26, 2019 Report Share Posted October 26, 2019 It helps if we know what brand of gear we are discussing. Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Imoski Posted October 26, 2019 Author Report Share Posted October 26, 2019 The only name I can find is "Venture Mfg Co" If it helps the RV is a 2008 Dutchmen Monte Vista 33re Quote Link to comment Share on other sites More sharing options...
chirakawa Posted October 27, 2019 Report Share Posted October 27, 2019 Bad contact on the switch. Quote Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Ray,IN Posted October 27, 2019 Report Share Posted October 27, 2019 12 minutes ago, chirakawa said: Bad contact on the switch. I'll 2X that. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Imoski Posted October 27, 2019 Author Report Share Posted October 27, 2019 That's what I'm hoping. Didn't get chance to check last night it was getting dark as we arrived! Quote Link to comment Share on other sites More sharing options...
Kirk W Posted October 27, 2019 Report Share Posted October 27, 2019 26 minutes ago, Imoski said: That's what I'm hoping. I would also check the switch first as that sounds like a strong possibility. Most likely you have a switch that is open in the center position and closed either of the other two positions(raise & lower). It may have one bad set of contacts. You can easily check it with an ohm meter, or as a quick test just use a jumper wire to connect between the lower contacts and the center. It will be very helpful if you have a multi-meter and are familiar with it's use. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
