Velos Posted November 23, 2019 Report Share Posted November 23, 2019 Usually if it sounds to good to be true it is.....I just saw an infomercial for HD Free Unlimited Antenna: https://www.hdfreeunlimited.com/?mid=11026678&gclid=CjwKCAiAzuPuBRAIEiwAkkmOSDZHDYjYnYEkGw3xGUiLpcRxRkK8_XJV-Vkt8r-4mTBPn1NUcKpxlxoCHhIQAvD_BwE Has anyone tried this? What is the catch? Quote Link to comment Share on other sites More sharing options...
Twotoes Posted November 23, 2019 Report Share Posted November 23, 2019 It’s just a new digital form of old fashioned rabbit ears. It will receive over the air signals in HD if you are in an area to find a signal. If you are out in the boonies you may not have a signal. Also you will not be able to receive Cable/Sat only channels like ESPN, Turner Classic Movies, CNN, etc. You will only receive OTA broadcast channels. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
Lou Schneider Posted November 23, 2019 Report Share Posted November 23, 2019 (edited) No catch, just overblown hype designed to reel in gullable people. I'm sure the package is exactly as described ... an over the air antenna that picks up local broadcast stations, the same as what you'd get using the Winegard antenna already on your RV. Plus a DVR that lets you record these broadcasts for later viewing. A quick Google search shows these are available starting at $36 from places like Walmart.com Edited November 23, 2019 by Lou Schneider Quote Link to comment Share on other sites More sharing options...
Velos Posted November 23, 2019 Author Report Share Posted November 23, 2019 We have been making some trips away from our RV and confess we like to watch TV but hate commercials so looking into something we can carry with us to put in rentals to record shows and replay without commercials. I will look into portable DVR's that we might be able to connect to the TV where we stay. Thank you for the suggestions. Quote Link to comment Share on other sites More sharing options...
rynosback Posted November 23, 2019 Report Share Posted November 23, 2019 I have been using Channel Masters DVR for almost 5 years now. Works great. https://www.channelmaster.com/OTA_DVR_s/336.htm I use a Firestick now to watch most of my shows. But then you will have a data concern not to mention how the signal is where you are. The more things you have in your arsenal the better you will be. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
docj Posted November 23, 2019 Report Share Posted November 23, 2019 We now are using YouTube TV for all of our OTR and cable channel viewing. It comes with an "infinite capacity" cloud DVR so we never have to worry about whether or not it's convenient to watch shows when they are scheduled. Yes, it does require data, but there are a number of truly unlimited plans now available from several sources. Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
ewacowboy Posted December 14, 2019 Report Share Posted December 14, 2019 On 11/23/2019 at 12:25 PM, docj said: We now are using YouTube TV for all of our OTR and cable channel viewing. It comes with an "infinite capacity" cloud DVR so we never have to worry about whether or not it's convenient to watch shows when they are scheduled. Yes, it does require data, but there are a number of truly unlimited plans now available from several sources. Are you traveling with the YT TV? I was told a year ago that it was not possible to get OTA channels in an RV with YT TV. If possible, are you getting a single location OTA or changing as you travel? Quote Jim and Kellie 2017 DRV 38RSSA Mobile Suite 2016 Western Star 5700xe YouTube Channel Link to comment Share on other sites More sharing options...
Tom_M Posted December 14, 2019 Report Share Posted December 14, 2019 On 11/23/2019 at 1:55 PM, Velos said: I will look into portable DVR's that we might be able to connect to the TV where we stay. The cheapest option is to pick up one of these: Ematic converter box Available at Walmart for $27.99. With the addition of a USB hard drive or thumb drive it becomes a DVR. I have one of these and there are some issues but once you get the hang of things it works quite well. Only one tuner. No skip function which means you have to fast forward through commercials. You can not start watching a show until it has finished recording. Very limited program guide. Sometimes channels will disappear which means you have to rescan channels. Quote Tom—————————————————2005 Born Free 24' Rear Bath Towing 1978 VW Bug convertible Minneapolis, MN Link to comment Share on other sites More sharing options...
docj Posted December 14, 2019 Report Share Posted December 14, 2019 13 hours ago, ewacowboy said: Are you traveling with the YT TV? I was told a year ago that it was not possible to get OTA channels in an RV with YT TV. If possible, are you getting a single location OTA or changing as you travel? You can get your hometown local stations as long as you login from there every once in a while. I think the TOS says that you have to log in every 30 days but the system didn't seem to be that strict. Because we were traveling for >3 months last summer we eventually lost our Corpus Christi locals and started getting locals from the cities we were near. But what was interesting was that the shows we were recording on the cloud DVR were still being fed from the Corpus Christi stations. You could tell that from the commercials. We could no longer watch those shows in real time but we could watch them immediately after they were recorded. I also tried using a VPN to see how it affected things. The system knew that I was using a VPN but it did let me change my local channels to Houston, which was one of the choices available through ExpressVPN. YouTube TV lets you change your official location twice a year. but since there are no contracts I'm not sure how they could stop you from starting a new subscription at a different location. Because we connect to Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
