homelesshartshorns Posted February 21, 2020 Report Share Posted February 21, 2020 I have a 2000 Suncruser with basement air that I love. I have a gas funerance that I hate. Problem is I don't want the gas funerance to come on at all at anytime. How can I simply cut it out of the system? Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 21, 2020 Report Share Posted February 21, 2020 If the furnace is on a dedicated fuse, unplug it. If not, there's a plug that connects to the ignition module in the furnace. Unplug it... Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Kirk W Posted February 21, 2020 Report Share Posted February 21, 2020 Remove the fuse that supplies power to the furnace? If that isn't practical you could also lift the 12V lead from the terminal block where it connects, usually found inside of the rear access panel for the furnace. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
homelesshartshorns Posted February 21, 2020 Author Report Share Posted February 21, 2020 If I take the wire off at the Furnace will it affect how the Thermostat works or mess with the gas? I understand the concept wonder if anyone has done this for themselves? Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 21, 2020 Report Share Posted February 21, 2020 All that will happen is if the thermostat calls for heat the furnace will not run. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
homelesshartshorns Posted February 21, 2020 Author Report Share Posted February 21, 2020 Ill try it! Thanks again for suggestions. Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Ray,IN Posted February 21, 2020 Report Share Posted February 21, 2020 (edited) Since the LP furnace and Coleman-Mach heat pump operation are tied together via the thermostat; when below a certain temperature the thermostat turn on both units until the inside temperature and outside temperature reach a specified range. When the basement unit begins to freeze up the 'stat turns it off until the outside temperature rises. That's my best shot at explaining how the combined system functions. For complete information and wiring diagrams see the service manual: http://www.rvcomfort.com/pdf_documents/1976323_copy8.pdf Edited February 21, 2020 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
GlennWest Posted February 21, 2020 Report Share Posted February 21, 2020 I would think just cut the thermostat wires and wire nut seperate and tape. All the gas furance does is make a connection at theremostat. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 21, 2020 Report Share Posted February 21, 2020 Unplugging the ignitor board does the job and is easily restored if needed or when selling the RV. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
homelesshartshorns Posted February 21, 2020 Author Report Share Posted February 21, 2020 Ok I unplugged a 5 or 6 wire plug in the Propane Furnace area. I now only hear the Thermostat click when Propane Furnace should come on, but it doesn't come on! The Heat Pump still works as it always has. It still acts as if the Propane is still there. Only working in the 1 or 2 degree range. But now if I forget to leave it on after shutting down the Generator. It will not turn on the Propane Heater with out me being aware of it. Thanks again for suggestions. Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Dutch_12078 Posted February 22, 2020 Report Share Posted February 22, 2020 Great! And it will be easy to reverse when/if needed... Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Kirk W Posted February 22, 2020 Report Share Posted February 22, 2020 17 hours ago, homelesshartshorns said: It will not turn on the Propane Heater with out me being aware of it If you are forgetful like me you should probably note the fact that the plug is disconnected somewhere just to remind you in case you should ever want to use the furnace. 😔 Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
homelesshartshorns Posted February 22, 2020 Author Report Share Posted February 22, 2020 That is what my Wife is for, I can blame her for not remembering what was done! Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
