Twotoes Posted March 5, 2020 Report Share Posted March 5, 2020 I have a hard time airing up my inside dullys. I have a Class A on a Freightliner chassis with 22.5 tires. Was considering putting extenders on but don’t really want to add a place where they can leak air. Looking into longer valve stems. Loves tire shop said they can add longer valve stems for $40 each side but I have to provide the stems. Anyone have any recommendations for purchasing long valve stems for an inside dully tire, online or store front? Thanks in advance. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
TexasPSDX Posted March 5, 2020 Report Share Posted March 5, 2020 I use these extensions https://www.raneystruckparts.com/6-straight-valve-extensions/ use stabilizers to prevent stem movement https://www.arconic.com/alcoawheels/north-america/en/accessories-heavy-valve-stem-extension-stabilizer-kits.asp Quote Ron 2020 Ram Longhorn 6.7 4D SB 1989 Avion 34V Link to comment Share on other sites More sharing options...
Twotoes Posted March 5, 2020 Author Report Share Posted March 5, 2020 Thanks, but as I said in my post, I don’t want to use extenders. I want to use a longer valve stem. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
Lou Schneider Posted March 5, 2020 Report Share Posted March 5, 2020 (edited) The 2" straight extensions on the page TexasPSDX linked to look like they have a center pin that opens the valve on the stock valve stem when you press on the end of the extension. This eliminates any chance of a leak as the extension is only pressurized when you're actually using it. I couldn't tell from the pictures if the 6" extension works the same way. Edited March 5, 2020 by Lou Schneider Quote Link to comment Share on other sites More sharing options...
kb0zke Posted March 5, 2020 Report Share Posted March 5, 2020 WHY are the valve stems pointed in on the outside tire and out on the inside one? Why not have both point out? I ask myself that question every time I check the tire pressures. Quote David Lininger, kb0zke 1993 Foretravel U300 40' (sold) 2022 Grand Design Reflection 315RLTS Link to comment Share on other sites More sharing options...
Dutch_12078 Posted March 6, 2020 Report Share Posted March 6, 2020 4 hours ago, kb0zke said: WHY are the valve stems pointed in on the outside tire and out on the inside one? Why not have both point out? I ask myself that question every time I check the tire pressures. So the wheels will be position independent. Using an appropriate truck tire gauge makes reading the pressures reasonably easy. https://www.amazon.com/gp/product/B000CONUJM Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Ray,IN Posted March 6, 2020 Report Share Posted March 6, 2020 13 hours ago, Twotoes said: Thanks, but as I said in my post, I don’t want to use extenders. I want to use a longer valve stem. I bought a 6" metal extension at a local auto supply store. It's only used when adding air is necessary; otherwise it is in my toolbox for the air compressor in the MH. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted March 6, 2020 Report Share Posted March 6, 2020 That is a pretty common problem with inside duals. On our class A's I did use extenders as I believed that tire pressures were something that should be checked every day of travel. When I replaced the tires I had the new ones mounted in a truck shop that put custom shaped valve stems on both inside duals so that I didn't need the extenders any longer. If you have a tire pressure monitor system, that will keep you aware of any loss of tire pressure. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Twotoes Posted March 6, 2020 Author Report Share Posted March 6, 2020 Thanks Dutch. I do have a truck tire pressure gage. The problem is that when I need to check or add add air I have to remove the TST monitor and it is difficult for me to do on the two inside dullys. And yes Kirk, when I hade new tires put on, at a semi truck tire shop, I asked them to put longer stems on but they were out of stock, so I am trying to do it now. Loves said they would do the labor but they need me to bring them the stems. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
jblo Posted March 9, 2020 Report Share Posted March 9, 2020 Try this website: https://hancousa.com/storefrontCommerce/itemDetail.do?itm_id=7133&itm_index=75&orderQty=1&cust_item=TPMVS-920&whs_id=1&orderUom=EA Might have to call them to explain what you need. Also, just check at another Loves for the stems. Joe Quote Link to comment Share on other sites More sharing options...
Twotoes Posted March 9, 2020 Author Report Share Posted March 9, 2020 Thanks Joe. I did check with another Loves location and was told the same thing. They will do the labor but don’t stock the park. You would think that a semi truck place would have the part! Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
Ray,IN Posted March 9, 2020 Report Share Posted March 9, 2020 6 hours ago, Twotoes said: Thanks Joe. I did check with another Loves location and was told the same thing. They will do the labor but don’t stock the park. You would think that a semi truck place would have the part! I agree, especially when they sell new tires and repair tires. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Ken Posted March 10, 2020 Report Share Posted March 10, 2020 Check out shinyrv.com Ken Quote Link to comment Share on other sites More sharing options...
