GlennWest Posted June 11, 2020 Report Share Posted June 11, 2020 (edited) Any of you ever considered a transformer for 30 amp service? So you would have split phase coming in. Know if you don't have any 240v, it is not needed. Edited June 11, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
DesertMiner Posted June 11, 2020 Report Share Posted June 11, 2020 You can add a “split phase “ output transformer to convert 30 amp single phase input power. Use a separate shore plug and add a transfer switch. It’s been done Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 11, 2020 Author Report Share Posted June 11, 2020 I was considering it in case I have to use 30 amp service. Would not have but 3600 watts but I could run my minisplit. It would not be exspensive. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
oldjohnt Posted June 12, 2020 Report Share Posted June 12, 2020 (edited) Glenn, I have covered this topic before but here goes. As you well know, an RV 30 amp pedestal has but a single leg of 120 Volt 3600 Watts and no 240. If you can buy a dry transformer that steps 120 up to 240 plus has a center tapped secondary (used as Neutral) you can end up with "120/240 Volt Single Phase Three Wire" in which L1 or L2 are 120 VAC to Neutral but L1 to L2 is 240 for your 240 Volt Mini Split. As you indicate this can work PROVIDED THAT it provides sufficient power ??? Being less then perfect you will get less then 3600 Watts output but if that's enough for your needs I say go for it. PS if the transformer is an isolation type you would have a Floating Neutral. It would be fun to see your system once completed, congratulations John T Edited June 12, 2020 by oldjohnt Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 12, 2020 Author Report Share Posted June 12, 2020 Oh, I have figured a different approach. Going to put a 30 amp receptacle on my camper. Feed a 110 receptacle with it. Use battery charger for batteries. Posted this elsewhere but getting 2 maybe 3 15 amp chargers. They $150.00 each. Are for my Leaf battery pack. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
oldjohnt Posted June 13, 2020 Report Share Posted June 13, 2020 15 hours ago, GlennWest said: Oh, I have figured a different approach. Going to put a 30 amp receptacle on my camper. Feed a 110 receptacle with it. Use battery charger for batterie Thanks for the update Glenn. Indeed that's a somewhat different subject and question that was first posted. To this new topic my thoughts are indeed if you have a 30 amp 120 Volt receptacle and a 15 or 20 amp 120 Volt receptacle adapter (for battery charger power cord) that can adequately supply a charger(s) that matches your battery charging requirements, GO FOR IT. Of course, there's only so much power available and your battery charger or multiple chargers can't exceed that DUH lol. I can envision a situation where 2 or more 120 Volt high capacity chargers (subject to their current requirements based on battery load) may well require MORE then any single 15 or 20 amp 120 Volt receptacle circuit can supply ????? Best wishes John T Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 13, 2020 Author Report Share Posted June 13, 2020 I have decided on 3 15 amp chargers. I checked out a 30 amp and it required a 20 amp 110v circuit. So even on an extension cord I could put 30 amps in. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
