chuckbear Posted August 9, 2020 Report Share Posted August 9, 2020 19 hours ago, LindaH said: I've been thinking about your comment. Has water intrusion through the holes ever been a problem when it rains, or does the electrical box sit up from the roof to allow water drainage? Linda. The DPH is weatherproof, but I did use some plastic shims caulked to the bottom of the DPH to keep it off the bottom of the box. In addition the vent holes are drilled on the sides at the bottom of the box so water runs right out. It's been through a lot of rain here in Florida with no ill affects. It sits about two feet away from the Travl'r. Chuck Quote Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
LindaH Posted August 9, 2020 Author Report Share Posted August 9, 2020 5 minutes ago, chuckbear said: Linda. The DPH is weatherproof, but I did use some plastic shims caulked to the bottom of the DPH to keep it off the bottom of the box. In addition the vent holes are drilled on the sides at the bottom of the box so water runs right out. It's been through a lot of rain here in Florida with no ill affects. It sits about two feet away from the Travl'r. Chuck Great! Thanks for the information! Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
chuckbear Posted August 9, 2020 Report Share Posted August 9, 2020 22 hours ago, LindaH said: Thanks for the suggestion. I'm surprised that the guy in the video didn't say anything about the DPH needing to be covered. It doesn't "need" to be but it helps with the longevity. With the switch on the roof, I only need the single coax through the roof, which was original with the DirecTV setup. So no new holes or running extra coax. Chuck Quote Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
Dutch_12078 Posted August 10, 2020 Report Share Posted August 10, 2020 The DPH42 hasn't been around long enough to have a good service life history, but I can say that Duo and Solo Nodes in the same style housing that have been in service outdoors unprotected since 2008. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
