GlennWest Posted August 30, 2020 Author Report Share Posted August 30, 2020 (edited) Took another reading. TV and dvd, Paula Dean roaster, dc lights, both mini splits.Temperature now 94 outside. L1 8-10. L2 10-17. DW is cooking and started microwave convection cooking.Light and fan on microwave. L1 now 31-41 L2 unchanged. Boy that microwave pulls some amps. DW told me see turned the roaster up from 225 to 300 just before I came in so that was likely the 41 amp display. It was 29, 31,29,41 on L1 on last 4 cycles. This is interesting, cooking is biggest draw. Edited August 30, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 30, 2020 Author Report Share Posted August 30, 2020 (edited) Ok, Microwave off Fan and light still on. Paula Dean roaster still on, Started dishwasher. L1 goes to steady 22. L2 11-14. Edited August 30, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 30, 2020 Author Report Share Posted August 30, 2020 Now only dish washer and convection microwave. DC lights, tv dvd. Mini splits, Fan and light on microwave. L1 24 L2 10 Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 30, 2020 Author Report Share Posted August 30, 2020 Judging by all this I will be fine with 2 4400 watt magnums. The mini splits really don't pull much at all. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
oldjohnt Posted August 31, 2020 Report Share Posted August 31, 2020 22 hours ago, GlennWest said: Judging by all this I will be fine with 2 4400 watt magnums. Glenn, I cant imagine TWO 4400 Watt units wont get you by... That's enough to power your own Zipcode lol and remember me parked next to you and plugged into your system...... Best wishes n God Bless John T Quote Link to comment Share on other sites More sharing options...
lockmup68 Posted September 2, 2020 Report Share Posted September 2, 2020 So when you are plugged into a 30a, is that just charging the batteries and you are running everything through the inverters? How's the 220 mini split operate if you only have 30a? Planning on a 3 cassette mini split, 220v, 1600 watts max draw on heat pump and 20a breaker required for the unit But there are a few places we like to go that only have 30a hookup. Assume Solar/batteries would make up the difference if needed. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted September 2, 2020 Author Report Share Posted September 2, 2020 (edited) Magnum plainly states in it's manual that it supplies split phase current even on 120v in. Now I can not verify this. If you go the Victron route, you will need two inverters. Run each leg to different inverter. Setup in software for splitphase and when you plug into a 30 amp circuit, one unit charges and other with assistance form the second produce split phase. Pulls energy fron battery to supply the voltage. Now I chose to go with a seperate 30 amp plug. I have bought 3 20amp chargers. P;lug into receptle box I have installed. Teton will be powered strickly from batteries and charged from 30 amp circuit. Now Steve Dixon in his Spacecraft used a 4dpt relay that when it sees 110v moves current to a dc power supply. That sends current to his Magnum PT-100 charge controller which charges his batteries. So you have 3 ways to do this. Well, he's fourth, solar. Edited September 2, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
