mptjelgin Posted September 14, 2020 Report Share Posted September 14, 2020 The amount of electricity an oxygen concentrator consumes is based on the amount of oxygen it produces. The 120 watt units are typically rated at 2 liters per minute, with the 350 watt units rated around 5L and a 10L unit rated at about 600 watts. Your required oxygen flow rate will likely govern the appropriate unit for your use, and the power usage will go along with it. Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
maryfair Posted September 14, 2020 Author Report Share Posted September 14, 2020 Mark, Here's where I got the information about the 120 watt unit: https://www.oxygenconcentratorstore.com/home-concentrator-comparsion/ It's the Inogen at Home 5L that says it's a 120 watt unit. I currently use 3 liters per minute and have the Respironics EverFlo unit. Maybe I misunderstood something. Quote Mary and Pete Link to comment Share on other sites More sharing options...
mptjelgin Posted September 14, 2020 Report Share Posted September 14, 2020 That does look like an efficient unit. It states "average" power usage so I guess that you'll just have to get one and check the wattage at your particular flow rate. Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
maryfair Posted September 14, 2020 Author Report Share Posted September 14, 2020 Mark, I'll work on that. it would reduce my power usage considerably. Quote Mary and Pete Link to comment Share on other sites More sharing options...
Randy and Helen Posted September 15, 2020 Report Share Posted September 15, 2020 I have four lithium batteries rated at 100 amps each or total 400. Gives me between 4800-5000 watts of power. I also have solar panels on the roof of 5th wheel and a 2800 true sine inverter. The fridge is 120 volts. I also have the inogen in home concentrator which draws around 120 watts and CPAP which draws total over 8 hours use of 380 watts. All together, when the sun goes down and no charging, with lights on and tv along with the fridge operating, total draw is 20-22 amps dc. So from around 5 pm until 8 am my total draw brings these four batteries down to A total draw of 300-325 amps. You may need to rethink this joule box as it may not provide enough power. Quote Link to comment Share on other sites More sharing options...
maryfair Posted September 15, 2020 Author Report Share Posted September 15, 2020 Randy and Helen, Your set up sounds like something that would work for me. Do you stop using the Inogen concentrator at 8am or do you run it off something else? From what I've learned in this thread I've decided that the Joule would probably not be a great set up for me. Quote Mary and Pete Link to comment Share on other sites More sharing options...
Randy and Helen Posted September 15, 2020 Report Share Posted September 15, 2020 2 hours ago, maryfair said: Randy and Helen, Your set up sounds like something that would work for me. Do you stop using the Inogen concentrator at 8am or do you run it off something else? From what I've learned in this thread I've decided that the Joule would probably not be a great set up for me. I only use my concentrator at night Quote Link to comment Share on other sites More sharing options...
Randy and Helen Posted September 15, 2020 Report Share Posted September 15, 2020 What kind of rv do you have. Fifth wheel or motor home. Does it have a generator or room for solar panels Quote Link to comment Share on other sites More sharing options...
maryfair Posted September 15, 2020 Author Report Share Posted September 15, 2020 We don't have an RV at the moment. We had a fifth wheel for several years when we full-timed. We were planning to buy a small (@30 ft.) motor home until we realized we needed to solve the oxygen concentrator issue first. Quote Mary and Pete Link to comment Share on other sites More sharing options...
Randy and Helen Posted September 15, 2020 Report Share Posted September 15, 2020 Please keep in mind that if you have an inverter to change dc to ac, you would be able to to keep your o2 concentrator working. But to keep the batteries charged up, you either need to have enough batteries to get you through the night and then charge with and on board generator or several solar panel to recharge those batteries Quote Link to comment Share on other sites More sharing options...
