Time to replace the propane detector?
Chalkie
A couple of days ago we started smelling a propane smell in the RV. As it was a nice day, all the windows were open and the Maxx-Air was running along with the ceiling fan. I went outside and checked all the tank connections and pipes. The smell was strongest in the kitchen and I finally noticed that one of us had apparently bumped a burner knob on the stove and the gas was on. Now the stove was covered as we never use it, the cover is the platform for the induction cooker. Anyhow, once the burner knob was turned off the smell eventually cleared. What worries me is that we could smell it but the detector did not and it is just on the other side of the sink cabinet, maybe 4 feet away.
Time to change out the detector do you all think?
Cheap enough to replace. The air movement may have been enough to confuse the detector, as it may not have been receiving a consistent strong "sniff".
2007 32.5' Fleetwood Quantum
Please e-mail us here.
Kind of what I was thinking. The one in here now now is an Atwood brand which is actually half again as much as one from MTI. Interestingly enough the MTI one says that it should be replaced every 60 months and has an End Of Life warning which I can find no information like that on the Atwood unit.
I don't know about your stove but on mine there is linkage that closes the propane valve when the lid is closed. You might want to look into whether your stove has that safety feature.
By the way the same thing happened to me (lid was open) and i thought it was sewer gas until the propane detector went off!
2004 Freightliner m2 106  2015 DRV lx450 Fullhouse  2019 Indian Springfield 2014 Yamaha 950 V-Star
It is actually quite easy to test one of those detectors. They look for hydrocarbons so you can just use a butane lighter without the flame to blow into the opening and it should alarm within about 15 to 30 seconds.
If you need to replace yours, Amazon has quite a range of propane detectors and probably one just like the one you have now.
Edited by Kirk W
8 minutes ago, Ray,IN said:
If I remember my LP fire training classes correctly, the human nose is 30X more sensitive than the best LP detector, the odorant in LP is mixed accordingly. The human nose can detect Ethyl Mercaptan at 0.001 PPM. The propane LEL =lower explosive limit is 2,100 PPM/2.1%
I suspect the LP detector did not sound because the open windows allowed adequate breeze to disburse the LP before it could reach the detector.
LP detectors are date-stamped and I think have a 5 year useful life.
Edited by Ray,IN
