trimster Posted October 11, 2021 Report Share Posted October 11, 2021 Got a dash message..." DEF system detects bad DEF. Derate in 60 min." I ran it to the the next town and did a parked Re-gen. New message is "120 min to de-rate". Got to the campground in an hour so I have time on the de-rate clock. Soot level is between 2 and 3. DEF was purchased from a Volvo dlr in June 23, 2021. I have a half DEF tank left. Does this stuff have a shelf life in the truck tank? Otherwise, I need some help on this one. I'm in Bernalillo, New Mexico, west of Albq. Thanks Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
SWharton Posted October 11, 2021 Report Share Posted October 11, 2021 I read someplace(RV Travel?) about a workaround for the problem. We no longer have an HDT so I didn't pay much attention. 2 RVers figured out the workaround. Quote Link to comment Share on other sites More sharing options...
HERO Maker Posted October 11, 2021 Report Share Posted October 11, 2021 Sorry, I can't help you on this one. I'm pretty much old school (2001). DEF does have a shelf life. Unopened and then possibly opened. Good Luck. Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 11, 2021 Report Share Posted October 11, 2021 Bad sensor. The shelf life of DEF is very long. Very long. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted October 12, 2021 Author Report Share Posted October 12, 2021 1 hour ago, Darryl&Rita said: Bad sensor. The shelf life of DEF is very long. Very long. Where's the sensor? Def tank? Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
jkoenig24 Posted October 12, 2021 Report Share Posted October 12, 2021 DEF "shelf life" is two years (possibly longer). RVTravel.com was following this problem and, in the last month or so, a software work-a-round was created. If I remember correctly, said work-a-round does NOT solve the problem. It supposedly STOPS the "De-Rate" from kicking in. You'll still get warning lights which can't be reset until the problem HAS been corrected. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 12, 2021 Report Share Posted October 12, 2021 2 hours ago, trimster said: Where's the sensor? Def tank? Most likely. I haven't been elbow deep into Volvo schematics, but KW has one there. It's basically a conductivity probe, if I remember right. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted October 12, 2021 Author Report Share Posted October 12, 2021 (edited) The RVTravel fix is for Cummins engines. Mine is a volvo. Not sure that will work. But I am going to start cheap... replacing the DEF filter. Found one at a local NAPA store. Easy replacement location. I'm not sure what has been done with this truck by the past owner, as far as annual maintenance. The dealership I bought it from threw out all the records left in the truck. So, we'll start with this filter and work our way to the spendy stuff. Edited October 12, 2021 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted October 12, 2021 Report Share Posted October 12, 2021 (edited) You can have bad DEF fluid and that is easy to check with a DEF Refractometer. Amazon.com: OTC 5025 Diesel Exhaust Fluid (DEF) Refractometer : Automotive The main problem is in the DEF sensor head. It is located in the DEF tank and combines a level sensor, quality sensor, temp sensor and a heater unit. There is a problem with all of them due to the corrosive nature of DEF fluid. I think Kenworth has 15,000 on backorder with MHC Kenworth having about 8,000 of those on backorder. Paccar and Cummins both have a software work around that was approved by the EPA to temporally "ignore" the DEF head issues until they can be replaced. They will record the VIN number of the truck when they put the software fix on it and you have to go back and get the sensor head replaced when it becomes available. There are guys that have been sitting at our local dealer since June waiting on a sensor head. We had the same issue and were lucky enough to get a replacement sensor head but if you try to find an OEM or aftermarket sensor head, make sure you get the right one. There are 3 different part numbers on our KW and they are not interchangeable. Edited October 12, 2021 by GeorgiaHybrid Quote 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
noteven Posted October 12, 2021 Report Share Posted October 12, 2021 An ammonia solution is corrosive? Yer kiddin. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
trimster Posted October 12, 2021 Author Report Share Posted October 12, 2021 Changed the DEF filter. Ugh. It was way past dirty. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 13, 2021 Report Share Posted October 13, 2021 Ewww! Can you track down a guy with a laptop, to go through all the parameters in your truck? Some manufacturers have a mileage/engine hour timer for that filter. It seems that should have been caught when you got the truck inspection done at purchase. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted October 13, 2021 Author Report Share Posted October 13, 2021 (edited) 26 minutes ago, Darryl&Rita said: Ewww! Can you track down a guy with a laptop, to go through all the parameters in your truck? Some manufacturers have a mileage/engine hour timer for that filter. It seems that should have been caught when you got the truck inspection done at purchase. Ya, inspection. It was a contentious purchase with Rush. Not much got done that should have. I think I'm gonna buy a code resetter. Not sure which one yet. Re-gen in progress. Fingers crossed. Edited October 13, 2021 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted October 13, 2021 Author Report Share Posted October 13, 2021 That didn't fix it. Now in full derate. Unplugging the speed sensor for now. Then taking it for a run. Maybe try the regen again after. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted October 14, 2021 Author Report Share Posted October 14, 2021 Just got back from the volvo dlr here in Albuquerque. Computer points to the SCR. Ugh. Spendy part. The service writer confirms what we mostly know, bad DEF is rarely the issue. "Typically some sensors get out of whack and all the computer knows how to respond is bad DEF." He also felt that the SCR failure is a bit premature in his experience. Truck goes in first thing tomorrow for the tech to prove further. A hard/hot regen might fix it....for now. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted October 15, 2021 Author Report Share Posted October 15, 2021 It looks like the NOx sensors (aftermarket) are causing issues. Has thrown 190 errors since the computer was cleared in July. Sensors have been in the truck since July last year. Still not convinced that this is the problem. More like service does not like them & want to sell factory....and they are charging me $250 core charge because they can't return them for Re-man. Not sure that's legit. So out the door...$2500. Parts, 4hrs labor, tax, core charge, regen included. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
lappir Posted October 15, 2021 Report Share Posted October 15, 2021 OUCH. Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 16, 2021 Report Share Posted October 16, 2021 Your aftermarket sensors, or from the sales yard? Sounds sketchy either way. A local dealership got caught red-handed a few years back when they tried to refuse warranty work on trucks with sensors from other brand dealerships. Swapped in their own shelf stock, and the problems remained. The deals included core charges, supposed re-programming to remove the bad sensors, etc. Tsk, tsk. This wasn't a case of freightliner parts on a Volvo, but KW on a Pete. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted October 16, 2021 Author Report Share Posted October 16, 2021 46 minutes ago, Darryl&Rita said: Your aftermarket sensors, or from the sales yard? Sounds sketchy either way. A local dealership got caught red-handed a few years back when they tried to refuse warranty work on trucks with sensors from other brand dealerships. Swapped in their own shelf stock, and the problems remained. The deals included core charges, supposed re-programming to remove the bad sensors, etc. Tsk, tsk. This wasn't a case of freightliner parts on a Volvo, but KW on a Pete. Bought the sensors thru eBay as I recall. I can't let let this go. Calling dlr service departments I trust for research. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted October 24, 2021 Author Report Share Posted October 24, 2021 Okay then.... core charge for NOx sensors is a thing. Legit. And of course the only take back factory cores. The truck is back on track. Running great. Soot levels are now very low. We'll see how it goes. The tech indicated that the next thing that will fail, based on their experience, is the SCR and that should happen around 700k miles. I'm at 668k. The SCR is a spendy bugger to say the least. So will I put on 40k miles over the next few years? Maybe not. This truck performs so well now. A pleasure to drive. Travel day tomorrow from where we are outside Albq. to the Petrified Forest for a few days. Then on to Phoenix for 2 weeks. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Sculptor Posted October 26, 2021 Report Share Posted October 26, 2021 Just read this. Hope it’s running great still. I bought nox sensors from eBay also. Still good after 2 or so years. Maybe just luck, but that doesn’t fit the usual pattern. I bought some fuel in Rock Springs and a few miles down the road got the forced regen derate message. (Which we did. First forced regen ever) Check engine has been coming and going, and soot level has been creeping up. For the previous month I had been driving short distance without getting up to temp twice a day. During or afterward never got any messages. Then drove most of the day to get to Rock Springs. No message. So far I blame my errors on the fuel. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
