GlennWest Posted March 6, 2022 Author Report Share Posted March 6, 2022 (edited) Found this and will give it a try. I am definitly low on amps. https://daygreen.com/collections/48v-60v-72v-to-12v-13-8v/products/36v-48v-to-12v-13-8v-80a-1104w-dc-dc-step-down-converter-voltage-regulator-3-years-warranty-newest I may just use this one on Hydraulic and get a smaller unit for lights, pump, blower motor. Edited March 6, 2022 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted March 13, 2022 Author Report Share Posted March 13, 2022 (edited) Well. I separated my dc circuits yesterday and installed a 12v marine battery. Slides are only items on battery and ac to DC converter. Nothing changed in slide operation. Do have 13+v to hydraulic now though. Going to run slides in today and remove extend hose and run unit to check for bypassing/leaking cylinder Edited March 13, 2022 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
57becky Posted March 23, 2022 Report Share Posted March 23, 2022 You might check the auto reset breaker on the line from the batteries to the pump motor. On the newer rigs that use #4 strand copper leads, Lippert recommends an 80 amp auto reset breaker as the amp draw from the pump motor can exceed 70 amps. https://manuals.heartlandowners.org/manuals/Exterior/Stabs_n_Leveling/Lippert/80 amp breaker lippert0058.pdf Quote Link to comment Share on other sites More sharing options...
GlennWest Posted March 23, 2022 Author Report Share Posted March 23, 2022 Mine totally different unit. Yes, lippert owns it now though. Mine has a self resetting circuit breaker. And only 30 amp too. That confusing as 60 amp DC/DC would fall on its face running it. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted March 25, 2022 Author Report Share Posted March 25, 2022 Looking at my rams shaft I believe I was overlooking the obvious. They rusted where I have neglected them. Likely leaking internally from damaged seals. Bedroom slide last out so it comes up short on fluid. Traveling pressure drops so opposing slides creep out and relax. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
