weBoost destination RV cell phone booster
GlennWest
We are in Victoria and cell phone service at Gateway RV is poor. Have 2-3 bars but data terrible. Was looking at this one and wondering how much wind will it withstand. Seems rather tall. Taller likely helps but gets windy here. Also how are y'all bringing cable in? On DRV I drilled a hole and sealed it.
Edited by GlennWest
Looks like the Destination comes with a directional antenna as did our RV Connect package. I purchased Drive OTR antenna which is omnidirectional that I have connected all the time, and usually provides a signal that is useful, but if not then I switch to the directional antenna that comes with the kit.
Drive OTR Antenna | weBoost
2005 Winnebago Voyage 38J
Glen,
They usually come with a flat cable you can run thru window or door. I ran ours thru the garage door on our drv toyhauler. The antenna is pretty stout with good mounts.
Ken....
2024 DRV Fullhouse JX450
2017 DRV Fullhouse JX450
2020 Volvo VNR 42-640, D13, 455hp, Ishift, 189"wb, factory single, ET Junior Hitch @ 195", Jacklopee, Directlink
2016 GMC 3500 Denali DRW, CC, LB, Curt 25k, Sold
Both my OTR and directional antennas have a round cable, not flat.  If you run the cable through a slide of window, make sure you are not pinching the cable as it can damage the shield.
Most of the time I use the OTR omnidirectional antenna.  In really marginal areas, the directional antenna really helps.
Edited by TXiceman
Mine had coax also, but there was a 8" flat cable that you could use for door or window or slide.
Ken....
If you are getting 2-3 bars it's likely that you are experiencing tower congestion. If that's the case a booster would do no good.
Tom
2005 Born Free 24' Rear Bath
Towing 1978 VW Bug convertible
Minneapolis, MN
If you are using a cell modem with 2 antenna inputs, connecting a pair of outside antennas will move the MIMO internal antennas to the roof - I have often increased the data speed by 10X using a pair of outside antennas & no amplifier.
Won't help with using a phone for data - no external antenna connections.
Then it might not help here. In the morning hours we can stream TV good. Afternoon not. Still going to get it.
I agree... Our aimable MIMO antenna set has equaled or outperformed our expensive booster amp everywhere we've used it so far.
What we have is the 8800L unit. It has two antenna ports on it. You got me thinking I just need an antenna. Which unit should i get. lots of them. I am going to take the wifi unit on top of of Teton today and see if signal increases.
Edited by GlennWest
1 hour ago, vermilye said:
I use a pair of these:  Chaowei High Gain 10-12dBi 4G LTE Omnidirectional Antenna-Wide Band Outdoor Pole/Wall Mount Antenna .  Note - they do not cover some of the 5G frequencies.
Not concerned with 5g. Grandfathered in with Verizon on device unlimited. On the link you showed I will need adapter for my 8800L unit.  Oh wife ordered a wifi extender. No use to us. You stated you used a pair. Is this helpful?
Edited by GlennWest
You will need 2 cables & 2 adapters.  Be sure the cables match the antenna - SMA to Type N and adapters SMA to TS9.
While I have not used it, if it works as well you could use this dual antenna and save $.  Still need the adapters...
One more question. I will need a flat cable for window. So order sma cable?
I wouldn't use a flat cable.  I don't know of one that has a SMA on one end & a Type N (the antenna connector) on the other.  I drilled a hole the size of the SMA connector, and caulked around the cable.  Permanent installation.  If you want a temporary connection, I'd install a port to run the cables.
I agree.  Flat cable may be OK when you're receiving a signal like from a dish to a satellite receiver or downlinking from the cell tower but transmitting is much more sensitive to cable irregularities.  It's likely to seriously compromise the power you're sending back to the tower.
Ordered a mimo antenna and installed it today. Terorary ran it thru window and checked it out. Way faster internet. Went from no streaming to streaming tv.. Tomorrow will drill hole for cable and make it permanent. Thanks everyone.
I am not questioning the success with a pair of omni directional antennas as suggested above. I am just curious how they work together? I have a pair of yagi (directional) that I am anxious to try. I would guess there would be no aiming of the pair of omni directionals???? thanks
1977 GMC Eleganza II
ARS WBOJOT
Using a pair of antennas makes them directional, based on a perpendicular line between the two antennas. That used to be very common for users of mobile CB antennas as it would push nearly all of the transmission power into the direction of travel. I have not heard of anyone pairing Yagi antennas.
The Complete Cellular Antenna Guide
Kirk, paired yagi's are commercially available. There are dual yagi's available on Amazon. I have stacked yagi's in my ham radio arsenal. I have two yagi's and have never them on my collapsible pole because they are physically different, even though they are electronically identical. But since they will join up at the 8800 I just never experimented with them.
Just never saw any improvement in pairing any omni directional but I am willing to learn. 🙂. Some of the boondocking YOUtubers use a paired yagi setup. I will try to find some examples. I do like this thread and will try to follow it. I also understand the phasing of two radiating elements in the transmission mode. In our remote search for signal, it is the receiving mode that is the most troublesome....(for me).
ARS WBOJOT
