homelesshartshorns Posted February 13, 2023 Report Share Posted February 13, 2023 I have a 2000 Suncruser with a backup camera. I would like to be able to turn it on while the engine is not running and also not have to turn on ignition. I would like to quietly see what's going on out back without having anyone back there know I am peeping. Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Kirk W Posted February 13, 2023 Report Share Posted February 13, 2023 That should be easy to do by just running a 12V supply with a switch in it. Exactly how will depend on the system that you have but it should be pretty easy as long as you have reasonably good access behind the dash where it is mounted. Keep in mind that if powered from the starting battery you could run the battery down with it. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
keloj30361 Posted June 6, 2023 Report Share Posted June 6, 2023 On 2/13/2023 at 7:39 PM, homelesshartshorns said: I have a 2000 Suncruser with a backup camera. I would like to be able to turn it on while the engine is not running and also not have to turn on ignition. I would like to quietly see what's going on out back without having anyone back there know I am peeping. if you would need to make modifications to your RV's electrical system, here is a general outline of the steps you may consider: Identify the power source: Determine if your backup camera is currently connected to a power source that is only active when the engine is running. You may need to locate the specific fuse or wiring connected to the backup camera to understand how it is currently powered. Install a separate power source: To power the backup camera without the engine running or the ignition turned on, you would need to install a separate power source, such as a dedicated battery or an auxiliary power supply. This power source should be capable of providing the necessary voltage and current for the backup camera. Wiring and switch installation: Connect the backup camera to the new power source using appropriate wiring and connectors. Additionally, you can install a switch or control mechanism that allows you to activate the camera without the need to turn on the ignition. This switch should be discreetly located and easily accessible for your convenience. Testing and safety considerations: After making the necessary modifications, test the setup to ensure that the backup camera is receiving power from the new source and functioning correctly. It is important to follow safety guidelines and electrical wiring standards to prevent any hazards or damage to the RV's electrical system. Quote Link to comment Share on other sites More sharing options...
RV_ Posted June 6, 2023 Report Share Posted June 6, 2023 https://www.amazon.com/dp/B09Z641NXZ?&linkCode=sl1&tag=rvtipstravels-20&linkId=bbf9fe32a827a7e26a18932150996184&language=en_US&ref_=as_li_ss_tl Quote RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
