jenandjon Posted June 15 Report Share Posted June 15 On my recent trip I stole the tire monitors off my work truck and put it on my trailer and HDT. I didn't reprogram anything so I had a constant low pressure warning on the drive tires because I only run 80 psi. I also had to scroll past unused tires. Other than that worked great. When I got home and switched everything back I noticed marks on the rims where the tire monitors flexed on the rubber valve stems. I don't know if this is something to worry about or not. One other funny thing happened. I had the monitor in the trailer charging one night and it started going off. I thought I had a slow leak in a tire. It showed an extremely hight tire temperature. We had been parked for 2 days and the tire in question was in the shade. Just a glitch I guess. I took it off the tire and reinstalled it. Then it went back to normal. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Jaydrvr Posted June 15 Report Share Posted June 15 I don't think you would want to be putting valve stem sensors on rubber valve stems. They are definitely going to move around with the extra weight on them. If you get a chance, you might want to change them out to metal stems. I always use metal stems on anything larger than a car. Jay Quote Link to comment Share on other sites More sharing options...
jenandjon Posted June 15 Author Report Share Posted June 15 I don't know if metal stems are compatible with these wheels. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 15 Report Share Posted June 15 Tough to tell from the pics. Tire shop visit time. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Jaydrvr Posted June 15 Report Share Posted June 15 1 hour ago, jenandjon said: I don't know if metal stems are compatible with these wheels. I was wondering that too. It looks really cramped. All the ones I've worked with passed the stem through the normal wheel opening. I don't think I've ever seen a wheel setup like that. Jay Quote Link to comment Share on other sites More sharing options...
Danfreda1 Posted June 16 Report Share Posted June 16 Had the same Tst monitor with readings like that but tire was fine. If you turn off and back on it was good. Took it to the big tent in quartzite where we bought it the year before and they replaced it. Glitches have been fixed he said. But we upgraded to the color monitor. Works great. No rubber stems. Quote Link to comment Share on other sites More sharing options...
Chad Heiser Posted June 18 Report Share Posted June 18 TST monitors are only supposed to be used on metal valve stems. Your lucky you didn’t have a catastrophic failure with one of your stems. Quote 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
trailertraveler Posted June 18 Report Share Posted June 18 (edited) 6 hours ago, Chad Heiser said: TST monitors are only supposed to be used on metal valve stems. Your lucky you didn’t have a catastrophic failure with one of your stems. This is from the TST website: "Note: Cap Sensors are compatible with Metal or Rubber Valve Stems" Quote On 6/15/2024 at 10:53 AM, jenandjon said: I don't know if metal stems are compatible with these wheels. I have been unable to find all metal valve stems that will fit the rims on my trailer. Have been using high pressure valve stems that have the rubber press in base with a metal stem with the TST cap sensors. We put about 15,000 miles on the trailer each year for the past 6 years. Replace the tires and valve stems every three years. No issues with the valve stems so far. I Edited June 18 by trailertraveler Quote Link to comment Share on other sites More sharing options...
jenandjon Posted June 30 Author Report Share Posted June 30 I emailed the company and I received this back. They claim I can use these with rubber or metal valve stems. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted July 13 Report Share Posted July 13 Our Jeep tow has had TST moniters on it since it was bought. It's been to Alsaka and back and all over the USA without any issues with the rubber valve stems. Quote 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
durangodon Posted July 13 Report Share Posted July 13 On the other hand, my brand new Casita had rubber stems on it on which I installed TST monitors. Within 1,000 miles from new, the stem flexed so much that it rubbed a hole in the rubber and lost tire pressure faster than I could get it off the road driving at 60 mph. Photo is of the rim after a new tire and metal stem was installed. You can see where the rubber stem had rubbed against the rim. I had metal stems installed on the other wheels, which showed signs of similar stem wear. All rubber stems are not built alike. Quote Link to comment Share on other sites More sharing options...
