GlennWest Posted Sunday at 02:45 PM Report Share Posted Sunday at 02:45 PM I know slide outs are the high leaker in heat/cold transfer. A heat leakage detector will really show lots at slide outs. Think tyvex tape would help. Once I set up in NC that will be it. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Chalkie Posted Sunday at 03:15 PM Report Share Posted Sunday at 03:15 PM 26 minutes ago, GlennWest said: I know slide outs are the high leaker in heat/cold transfer. A heat leakage detector will really show lots at slide outs. Think tyvex tape would help. Once I set up in NC that will be it. Tyvec is breathable so it will not provide any barrier to heat or cooling. When used on houses it provides a waterproof barrier that will let moisture inside the house to escape. If you are sure you are never going to move it again, i.e., no need to ever pull the slides in again, I would suggest using non-expanding spray foam. It will seal against water intrusion plus it has an insulating value. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted Sunday at 03:51 PM Author Report Share Posted Sunday at 03:51 PM Yes, agree. I would have to get creative in making it look good thouugh Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
HERO Maker Posted Sunday at 05:03 PM Report Share Posted Sunday at 05:03 PM Pool noodle cut in half and shoved in. Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
DanZemke Posted Sunday at 05:43 PM Report Share Posted Sunday at 05:43 PM 2 hours ago, Chalkie said: Tyvec is breathable ... But Tyvex tape is not. Glenn, regardless of what you decide, suggest you do a trial-run on your smallest slide-out first (so any re-dos are less expensive). Perhaps build a little roof frame out of aluminum, steel or standard lumber? Add a sheet of water proof plywood, topped with residential shingles? Insulation could be like a house - fiber glass or sheet foam. Attic fan? Hopefully, it will be a fun and productive project. Good luck Quote Volvo 770, New Horizons Majestic and an upcoming Smart car Link to comment Share on other sites More sharing options...
GlennWest Posted Sunday at 05:51 PM Author Report Share Posted Sunday at 05:51 PM Yes, going to put a roof on. Have to transfer solar. Won't be singles though. Metal roof on anything I do. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Chalkie Posted Monday at 03:23 PM Report Share Posted Monday at 03:23 PM 21 hours ago, DanZemke said: But Tyvex tape is not. Well, true, but it certainly has no insulating value. As a side note, both you and Glenn are calling the product the wrong name. It is Tyvek. Used to see that brand name on 100s, if not 1000s, of floppy disc envelopes and other packaging in the military. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted Monday at 04:11 PM Author Report Share Posted Monday at 04:11 PM I spell a lot wrong. lol. I still call an adjustable a Cresent wrench Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
