GlennWest Posted July 10 Report Share Posted July 10 (edited) We have an Amanda stove top and igniters no longer work and parts are no longer available. Mine is 21 ish" wide and opening can't be changed easily. Is the Surburban the better unit or Atwood. Edited July 11 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jbh Posted July 11 Report Share Posted July 11 I ended up using a Greystone cooktop and it's been fine. The current Attwood was about a half-inch wider than the '93 Attwood and I wasn't about to try cutting the corian countertop to make it fit. Quote -C&J- CG reviews & more - www.fugawetribe.com Link to comment Share on other sites More sharing options...
GlennWest Posted July 11 Author Report Share Posted July 11 Most I find are 2 burners. Personally think that be fine but DW wants to stay with 3. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Ray,IN Posted July 12 Report Share Posted July 12 Have you considered switching to an induction cooktop? If you both have considered it, now would be the best time. DW has already told me, if our 24 yr old LP cooktop quits, she wants an induction cooktop. Greystone Electric is another mfgr. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
GlennWest Posted July 12 Author Report Share Posted July 12 (edited) It would require a 20 amp breaker. Not sure how much trouble to pull a wire would be. It is on a slide out and breaker box on opposite side. The Dometic is a 1400 watt unit. It may work on a 15 amp circuit. 1800 watt is max for 15 amp Edited July 12 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted July 12 Author Report Share Posted July 12 We going to stay with gas. We will be on the east part of NC. Every so many years we loose power from hurricanes. Sometimes from ice storm. That gas stop top be sweet then. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted July 23 Author Report Share Posted July 23 We put the Atwood slide in unit. I was very disappointed in the lower frame. Very thin sheet metal. Unit had movement with it. Took it back off, trashed the bottom piece. Added aluminum angle to sides and screwed it down. Solid now. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
