Deezl Smoke Posted July 16 Report Share Posted July 16 Considering this Pioneer unit. https://www.pioneerminisplit.com/products/pioneer-12-000-btu-21-5-seer-8-way-compact-cassette-mini-split-air-cond-heat-pump-system-full-set I looked through the literature the manufacturer has with no luck. I then tried to call with no luck. I then sent an email, and still have not heard back, which is not a good sign, but...... So my question is, the indoor cassette unit, can I mount this vertically instead of horizontal? I do not need the condensate drain pump system, and can install my own drain hose connection at the bottom (installed orientation bottom). In the old days a brush type motor sometimes would be made with bearings that preferred to only be ran in the original design orientation. Today that does not seem to ever much be a concern, however.....? It is mounting space limitations that require the need for this indoor unit type. Thank you for any information. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
GlennWest Posted July 16 Report Share Posted July 16 Go to highseer.com. They are the distributor for Pioneer and offer great support and warranty. Also the cassette goes in one way only. It hangs on rods. Pioneer also has a slimline unit also. Fit between your studs. I would have used the slimline if it had been on market when I did mine. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lappir Posted July 17 Report Share Posted July 17 My reading of the instructions indicate to me that it's not a wall model and only acceptable installation is in a ceiling. I've seen wall mounted units, but not by this company. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
GlennWest Posted July 17 Report Share Posted July 17 Pioneer has plenty of wall mounted units Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Deezl Smoke Posted July 17 Author Report Share Posted July 17 I watched a video on ceiling cassettes, and it sounds like the only issue would be the condensate drain. I can easily correct that issue. They also said very high humid areas may need to insulate the outside of the cassette as it may sweat and cause water damage to the surrounding material. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
GlennWest Posted July 17 Report Share Posted July 17 (edited) I built a plywood box insulated in opening and hang cassette inside it. Been running for years now, no problems. And most of my use has been in the southern Texas and Louisana area Edited July 17 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
