RV_ Posted Wednesday at 07:23 PM Report Share Posted Wednesday at 07:23 PM (edited) Written by Ed Bott, Senior Contributing Editor Ed is one of the old guard reliable techs that I listen to when he writes. If you aren't comfortable doing any of this then don't. Excerpt: "You don't have to get rid of a perfectly good PC just because it doesn't meet Microsoft's strict Windows 11 compatibility standards. Here's how you can bypass the restrictions and safely upgrade your Windows 10 PC - for free. On October 14, 2025, Microsoft will stop delivering security updates to your Windows 10 PC unless you're willing to pay an exorbitant price to join the Extended Security Updates program. If you try to upgrade to Windows 11 on a PC over a few years old, you'll be told, in no uncertain terms, that your old PC doesn't qualify because its CPU isn't on the official list of compatible processors. Microsoft has made it abundantly clear that it will not revise those requirements. You will also hit roadblocks if your PC doesn't have a Trusted Platform Module (TPM) version 2.0. While that might be the official policy, as with everything Windows-related, it pays to read the fine print. Those pesky restrictions prevent you from automatically upgrading to Windows 11 using Windows Update or the Windows 11 Installation Assistant. Yet there are fully supported workarounds, as I document in ZDNET's Windows 11 FAQ. An important note: To take advantage of the workaround described in option 1 below, your computer needs to meet all the other requirements for Windows 11. It must be configured to start up using UEFI, not a legacy BIOS configuration. Secure Boot must be enabled. Also, you need to have a TPM enabled; version 1.2 is OK but a system without any TPM or with the TPM disabled will fail. To check these details on a PC you're considering upgrading, run the System Information utility, Msinfo32.exe, and look at the System Summary page. Pay special attention to the BIOS Mode value. If it says "Legacy," you'll need to reconfigure your system to UEFI mode (and convert your system disk from MBR to GPT partitioning) before you can install Windows 11 as a normal upgrade. To see whether your PC has a TPM enabled, run the Trusted Platform Module Management tool, Tpm.msc. If your computer includes a TPM and it's turned on, this app will display information about it. If there's no TPM, or if the TPM is disabled in firmware settings, you'll see a message that says "Compatible TPM cannot be found." If you're unable (or unwilling) to change from Legacy BIOS to UEFI, or if you have an older PC that doesn't have a TPM option at all, you'll need to use an undocumented hack to complete the upgrade. See option 2 at the end of this post for details on how to use the free Rufus utility to perform this upgrade. If you plan to perform a clean installation of Windows 11, you can boot from installation media and run Windows Setup. That option skips the CPU compatibility check completely (but still requires a TPM and Secure Boot support). After the installation completes, you'll need to reinstall all your apps, restore your data files, and tweak settings to personalize your system preferences. Want to avoid all that hassle? Follow these four steps." Detailed instructions are in the full article here: https://www.zdnet.com/article/how-to-upgrade-your-incompatible-windows-10-pc-to-windows-11-two-options/ Edited Wednesday at 07:26 PM by RV_ Quote RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
